Let me first start off by thanking Ron for his astounding work on the carb and head. I could not be more pleased with his craftsmanship.
That being said, on with the show!!
First, at the beginning of last season I bought a 2005 KDX220R. I rode it over the course of that season and came away with a good impression of the bike. It did everything I needed it to do as a novice. As I got better with the bike I found myself desiring more response and power. Most of my riding happens in the tight wooded trails of Oregon and my primary focus is torque and throttle response. (Speed is a byproduct) The RD carb and head mods seemed like the best choice to enhance my riding style.
I posted earlier asking if anyone had feedback about using the RD carb and head mods with stock pipes. But, it seems that most everyone buys the exhaust system first. In my case I choose the cheaper of the two options. Not to mention, I wanted to avoid downtime in the middle of the riding season.
After picking up my parts on Saturday, I had to wait until last night to put them back on the bike. (Have to put in girl time before ride time) The bolt on was much easier than the tear down. I knew where things went and what to expect. Once it was all together I added a new plug, some gas and kicked it over. On the second kick it sprang to life and greeted me with a meaner sounding growl, almost primal. I touched the throttle just a bit and it responded instantly with a snapping bark.
I gave the bike time to warm up and settle, and took the seat for my first ride. On the first twist of the throttle I was impressed. The front wheel was up off the ground so quickly I was forced to tap the rear brake so as not to end up on my back. Second gear was much the same. Wow, the hit was amazing.
After returning home I decided it was time to find that second sweet spot (SSS) that everyone talks about on this forum. After an hour of cutting figure eights in my parents field and bogging the bike down in low speed third gear corners I was able to find the spot. I knew I had it as I came out of the low speed corner in third and it did not want to bog and die at half throttle. Instead it just pulled out of it and then accelerated away. I was truly impressed.
As a final note I want to say that with the stock pipes the RD carb and head mod is well worth the investment. I would not say that the overall speed of the bike is increased all that much but, the response and hit are very noticeable. There is a much better power curve to the bike now and the “Indy car” like throttle response is amazing. I am looking forward to stacking some money away to get the new exhaust as well but, that’s going to take some time.
So once again, hats off to Ron. The mods make an incredible difference even with mostly stock components on the back end. Thanks to all of you for your input on making my KDX riding experience that much better. I look forward to seeing you all on the trail.
If you have questions, please ask. I will give as much feedback as you need.
-Xagentman
