Good questions.
I have no answers.
IF the FmF site says the only pipe is a Fatty, then I'd guess that is what it is.
The Fatty existed for earlier 200/220 KDXs..was advertised to be a 'moh betta' pipe..the best of everything. But...I've SEEN Fatty pipes on 'H' model KDXs, too. I don't know if that is because they simply fit..or that pipe was realigned to MAKE it fit (like most FmF pipes require!! ;) )
You probably read this already...but a larger bell is generally a higher RPM range pipe than a smaller bell for the same bike. But..that leaves out a lot of stuff..like the length/diameter of the header section for one thing.
FmF says (of the Fatty '92 250 pipe):
FmF wrote:Offers a hard hit right off the bottom and pulls hard to high RPMs, surpassing the stock pipe at every level. 10 to 12% horsepower increase over the 6,000 to 10,000 RPM range.
For the 200 'H' series, FmF says this about their 'desert' pipe:
FmF wrote:Designed to withstand total offroad abuse, the Gnarly concentrates on tractable power. Extra thick 18-gauge steel ensures a long service life. Features enhanced low RPM pulling power without sacrificing mid-range pull.
AHA...but check out what FmF says about the 'woods' pipe!!!
The difference is plainly obvious, no?
Both of those quotes from the BikeBandit site.
FmF has
NEVER had a clue what they are doing marketing-wise. They are absolutely INCAPABLE of describing their products, let alone making their products FIT the intended application.
No worries, though. If you have ANY questions, just ask FmF tech!!
Their answers have always been the same anytime I've asked them:
FmF Tech support wrote:
There 'ya have it!!!
