Page 1 of 2
clamp between expansion chamber and silencer
Posted: 09:48 pm Jan 16 2007
by vinny
I am having a hard time finding this item in the aftermarket. The only ones I have found are shiny expensive ones. We all know you won't be able to see it. Would a piece of heater hose work or would there be too much heat for it. The rubber is boken on mine and the factory one is $20 which is a little high in my opinon.
Vinny
Posted: 09:52 pm Jan 16 2007
by KDXer
I took my stock rubber piece to an auto shop and matched it to a radiator hose. For $10 I was able to make 4 with the hose supplied.
Posted: 10:01 pm Jan 16 2007
by vinny
Thanks KDxer!
Posted: 02:00 am Jan 17 2007
by Mr. Wibbens
I use nothing but high temp silicone on the joint
Posted: 08:55 am Jan 17 2007
by vinny
Silicone what? Hose? If so where did you find it.
Posted: 11:47 am Jan 17 2007
by Mr. Wibbens
No hose, just silicone, Capisce?
Posted: 01:35 pm Jan 17 2007
by KanuckKDX
Mr. Wibbens wrote:No hose, just silicone, Capisce?
Not yet I don't.
So you put silicone over the muffler end and the silencer slides over the silicone and seals the thing.
And next time you pull it off, you scrape the silicone off both parts and do it again.
Or am I still too dumb to figure this out?
And why are you doing this rather than use the typical hose and clamps?
Posted: 03:26 pm Jan 17 2007
by bradf
I use Blue 77 or Copper too, no hose or clamps.
Posted: 03:50 pm Jan 17 2007
by scheckaet
I stuf both ends with cheap clear silicon (not high temp) and and use the rubber part.
it seems to hold pretty well
Posted: 04:39 pm Jan 17 2007
by vinny
I'll have to look into this more because I swear there is a gap between the silencer and pipe and one will not fit over the other. Now I did fail to mention that this is a FMF set up. If that matters.
Vinny
Posted: 05:30 pm Jan 17 2007
by scheckaet
I also have a FMF set up, I am confused about
If you are refering to the "male-female" connection, I believe the pipe end goes inside the silencer end. I siliconed the pipe end, installed the rubber piece on the silencer end then fitted everything together on the bike.
I don't know what clamp you are refering too, mine (05 200) only had the rubber piece that covers the junction, is this what you calling clamp?
Posted: 05:34 pm Jan 17 2007
by radonc73
I have 2 hose clamps at the ends of my hose, also. Mine came that way with the snail type clamps, I just assumed everyones were the same.
Posted: 05:52 pm Jan 17 2007
by vinny
I also failed to mention that my bike is a 1993 200cc. I just checked and my silencer will slide over the expansion chamber end but I don't know if the holes on the silencer will line up because I will have to slide the silencer forward on to the head pipe. If you get my drift. Also even if you use silicone you still have to have something to hold the two together because I don't think silicone would be enough. It may seal but it has little holding strength.
Vinny
Posted: 06:00 pm Jan 17 2007
by scheckaet
don't know about 93 but the silicone and rubber part are just there (as far as I know) to seal both ends and not having spooge dripping all over the place.
If you are saying the pipe and silencer don't line up, you may have to persuade them...
I think I had to drill a bigger hole on the silencer on mine to make it line up with the mounting hole on the bike
Posted: 07:51 pm Jan 17 2007
by Mr. Wibbens
Not yet I don't.
I dunno?
Sounds like you got it figured out to me
Why?
More like why not?
Posted: 09:39 pm Jan 17 2007
by KDXer
I reckon slipping a piece of rubber hose on and off is alot easier (and less messy) than pasteing silicon all over the joint. Just my 2c.
BTW I use zipties to keep it in place even though it doesn't need em.
Posted: 10:32 pm Jan 17 2007
by Mr. Wibbens
I don't know about less messy
Smear a little on during assembly, and it peals right off when you are ready to repack
Not much mess and it seals much better than the hose
Posted: 10:41 pm Jan 17 2007
by KDXer
Mr. Wibbens wrote:it seals much better than the hose
Really ?!? Stock hose maybe ?!?
I would have thought that a piece of rubber hose would be a stronger seal than silicon. To each their own though....
Posted: 10:47 pm Jan 17 2007
by Mr. Wibbens
stock hose on mine leaked spooge, even with hose clamps
silicone properly set up, no leaks, no mess
Posted: 10:50 pm Jan 17 2007
by Indawoods
AWESOME WIBS!
This thread over?
