Chain slack?
Posted: 06:53 am Jan 06 2007
by cfspawn
Hey all just thought i would share a few things..
From what I have read 110 link chains are stock for the kdx's (states in the manual) on a 13/47 config, from what i have read on here a 108 is advised on a 12/47 setup which i have. I put my new chain on last night to find there is no way 108 links will fit.. to short! so 110 links was perfect with the snail adjusters on 2 1/2. Just wondered on what a good slack for the chain is from what I can tell its pretty good. pic is below.
Posted: 07:38 am Jan 06 2007
by Jeb
Per the manual: bike on side stand, grab middle of the upper run of chain (at the rear of the chain slipper). Rotate rear wheel to find where chain is tightest (wear will be uneven). Adjust for 55-70mm (2.2-2.8").
Thanks for sharing about the # of chain links - I'll be switching to a 12-tooth sprocket some time as well!
Posted: 09:06 am Jan 06 2007
by cfspawn
Hey Jeb
There is NO way possible for a 108 to fit, *EDIT*ON A E SERIES.*EDIT* 110 links are the go
H H H H H H H H...well...at least SAY
Posted: 03:14 pm Jan 07 2007
by canyncarvr
Curious what manual that is and where you read it.
>|QBB<[/url]
cfspawn wrote:Hey Jeb
There is NO way possible for a 108 to fit. 110 links are the go
To put it simply...you are wrong....for 'H' model KDXs anyway. You didn't mention that part.
I've run 108links for the bike's whole life. I've run 12/13 and 47 toothed sprockets.
Either you counted incorrectly (you're wrong) or your chain is longer than OEM..(108)...and you're still wrong.
Now....you can be wrong all you like and it doesn't bother me one way or t'other. The problem is posting it as being right and everbody ELSE is wrong.
While that situation may indeed be true sometime...it ain't true this time.
OEM chain is 108. OEM sprocket set is 13/47. OEM chain will fit fine on a 12/47 setup.
Period.
Cheers!
BTW...from the 'H' manual:
Posted: 05:12 pm Jan 07 2007
by cfspawn
Yes All good there
Obviously the E series are different from H Models. as 110 links are stated in the manual on a 13/47 setup. I did not mean to come across that everyone is wrong i was just saying thats the way mine was. all good though as long as it works!. :lol:
Posted: 11:14 pm Jan 07 2007
by canyncarvr
It's the good part that's good.
If you run 110 links on an 'H' model with a 12/47..you're going to run out of snail room.
Who knows what those down under SR models do.......... :roll:
Jeb doesn't run an SR...I think. :hmm:
Posted: 11:26 pm Jan 07 2007
by KDXer
Something smells fishy here. Maybe a swingarm length issue between H vs E models ??
55 side plates is 110 links, correct ??
Ahem CC, the picture clearly shows a E series. :wink: :mrgreen:
Posted: 11:30 pm Jan 07 2007
by cfspawn
Yeah i agree CC 108 makes sense with a 12 tooth sprocket. but if i cut at 108 i would have had to take the snail adjusters off to make it fit.
May bee the swing arms are longer.. dunno just a thought
Posted: 12:21 am Jan 08 2007
by canyncarvr
AHEM!!..
Yes. But then:
...and Jeb don't.
Yeah. Something is fishy....but I'm not going to let it keep me awake tonight (Sunday night...way past for SR folks........)
The point was..54 is correct for the 'H' model. If 55 fits fine for an 'E' model...that's fine, too.
But put 110 on an 'H'..and there are going to be some problems.
55 plates including the master is indeed 110 links. But..if you ORDER 110 links..that's not what you count on the chain before you put the master IN.
Posted: 12:35 am Jan 08 2007
by cfspawn
Yep i ordered a 120 link chain, and just cut it from there.
Posted: 06:12 am Jan 08 2007
by Jeb
I counted a total of 54 sideplates last night including, of course, the master link. 'Stock gearing . . .
SR? Street Ready? 'Not real sure what SR even stands for . . . no, just checked. I thought I would find "EW" for Eastern Woods but it's an "A" model, and "A10" to be precise. They must have completely started over on the alpha-numberic sequencing when they started manufacturing the 220s - you know, the new & improved model. :mrgreen:
Hey Spawn - don't forget to check your slack :wink:
Thanks for the double-checking and clarifications guys, seriously :grin:
Posted: 07:25 am Jan 08 2007
by cfspawn
hehe Glad we cleared it up..
