Sag, rake, trail, distances from axle to axle, etc.
So, I've decided to use KDXRider as a virtual filing cabinet (and maybe snag some astute commentary).
Static Sag: ~ 1.9 to 2.0 inches
Race Sag: ~ 5.5 inches
(I bought the bike set up for 150-pound QuailChaser).
The following measurements will help me figure out if the geometry is similar both pre and post mod. Hopefully this will help me avoid, or dial out, any skittish handling problems that might crop up:
Distance center of rear axle to center of front axle= 56.75"
Rake = 65-ish degrees (measured with a crappy carpenter guage)
Trail = 7-inches (measured from the axle); or 4.5" (from the rear of the fork).
I've also measured from a point on the radiator shrouds as well ( 25-left, 26-right).
Here is a diagram of the Rake & Trail measurments...
The forks that Krazynski will be sending me are rebuilt and set up as follows:
Springs = .43 (my ride weight with gear and Camelbak is @ 224).
Krazy said he went by CC's base valve stack:
24x15 (4)
22x15
20x15
17.5x15
16x15
11x13 (2) (measured .005")
17.5x50 (2)
I should have all the parts I need sometime this week. With any luck, I'll be modded and ready to test next weekend. Ready to ride the weekend after.
Thanks all, for your help.
Rick
