They have 95 octane pump gas in OK
nope, was thinkin about my top speed
, I meant 91 or wahtever the highest at the pump is
The line opposite the ground electrode is...not a crack, right?
nope not a crack, it was some of that greyish deposit (carbon?), actually more like tanned brown (defenitly NOT white grey)
I do see some white grey on the tip of the electrode.
The moist is more on the outer part (screwing part)
When you took the carb out, did you take the boot off? The reeds out?
I only took the carb out.
ok
here is what I am running: (200 05 model)
stock needle, middle clip
pilot: 45
main 158
air screw 2.5
(The stock was:
pilot 48
main 160)
It seems odd to me now that the dealership gave me this when I asked for 1 size down
...(I assumed at the time this was normal, now I have my doubts)
I ran about 35 miles this morning and showed the plug to one of the guys and said it didn't look lean.
Is there a website with pics of what a lean condition looks like?
The inside is dry but not white-grey more like brown-taned.
I will get 1 size up next week no matter what and see what the plug looks like after a ride.
As far as changing the mix ratio... since I'm not the best at getting perfect jetting (obviously
) i'd rather be on the safe side and run a bit too rich than too lean. Maybe when i'll get more comfortable with jetting I'll try another mix ratio.
thx
wilf
