Inda..I'm sure you've said, but what oil/fuel ratio do you use?
Not to get picky, but detonation is defined as:
A condition, in which, after the spark plug fires, some of the unburned air-fuel mixture in the combustion chamber explodes spontaneously, set off only by the heat and pressure of air-fuel mixture that has already been ignited.
(From:
http://www.autocenter.com/about/ ..returned by Google from 'define')
Note that detonation does not necessarily have anything to do with pre-ignition. Maybe it happens during 'normal' properly timed and sourced ignition.
Yes, pre-ignition is different. It is ignition of the mix prematurely and not from the primary ignition source, hence the 'pre' part.
Hence why I said I don't know what
predetonation is. I've not heard that term..I think it's misspeak in this case. Certainly some situation does exist just prior to detonation, but I don't think it's coined 'predetonation'.
Yes, I understand the following definition of 'pinging' is out there, too:
Knocking (also called pinking or pinging)—technically detonation....
It is my understanding that the two (detonation/pinging) are NOT the same. I don't think every detonation leads to a 'ping' that you can hear..thus the 'silent killer' part.
Detonation can be resolved by increasing octane, but also by redesign of the head to preclude 'pockets' from developing and by intake design that brings about a better 'flush' of spent fuel AND a consistent mix of fresh fuel (like 'turbo swirl' heads. Part of why the term 'port and polish' is so stupid.).
And there's the squish band of two strokes............
It's more complicated than 'It's the octane.'
Like Inda said....many variables.
BTW, I have a dyno, too! I've found it works great particularly when properly prepared prior to riding..lubricated if you will...using Ski's butt crack cream.
Available in the 'Feminine Hygiene' aisle of your local drug store...it's a Monostat product.
(For those in Rio Linda, I'm referring to a 'seat-of-the-pants' tattle. That's
my dyno! Ski's cream
does work great!!)
