Gear lever/shifter
- KDXer
Gear lever/shifter
What would be my best option for a replacement gear selector as I broke mine at the dunes and need a replacement ?? It's just I recall someone saying to stay away from after market ones.
Any and all help mostly appreciated.
Cheers,
Trev...
Cheers,
Trev...
- quailchaser
Re: Gear lever/shifter
Was that here? http://www.kdxrider.net/forums/viewtopic.php?t=2772KAY DEE EXER wrote:It's just I recall someone saying to stay away from after market ones.
Cheers,
Trev...
OEM is probably your best choice. Moose steel is second.
Robb
'02 KX250
PW80 for the Gman
AMA
Off Camber M/C
BRC
AZOHVC
'02 KX250
PW80 for the Gman
AMA
Off Camber M/C
BRC
AZOHVC
- KDXer
- KDXer
That's like 35 cents American ain't it????
- KDXer
- quailchaser
- KDXer
Not all that ugly but the main thing is it works.
Thanks Quailchaser for your help.
For the record the following shift levers are the same as a H model KDX one.
KX60 83-02
KX80 86-05
KX85 86-05
KX100 86-05
KX125 83-93
KX250 83-93
KX500 83-93
KLX250 THRU 80
KDX200 83-06
KDX220 97-06
KDX250 ALL EXCEPT 83
shift shifter lever gear (for search results)
KX60 83-02
KX80 86-05
KX85 86-05
KX100 86-05
KX125 83-93
KX250 83-93
KX500 83-93
KLX250 THRU 80
KDX200 83-06
KDX220 97-06
