stiffer kdx fork springs
Posted: 05:37 am Aug 26 2006
by motofox2006
Hi guys can anyone tell me what stiffer fork springs out of xr400 0.38kg springs and OEM kdx 1995-2005 0.35kg springs I need.
I weigh 146Lbs (66kg)
Jeff Fredette says on his site that for my weight category i need 0.35kg/mm springs for my weight. However on Race Tech spring calculator it says i need 0.40kg springs for my weight.
Anyone got any ideas.
Any help appreciated Thanx guys
Posted: 07:42 am Aug 26 2006
by krazyinski
go with the .35 for your size or .38. I am 165 and run the .40
Posted: 09:50 am Aug 26 2006
by m0rie
I ran 0.40kg XR400 springs in my stock 89 forks. Worked well for my 175lbs weight after I got the oil weight down (7w from 10w) and ran a minimal amount of preload (3mm). I'd try 0.35kg 95+ KDX stock springs for your current weight. I've got a set if your interested in giving them a try.
Posted: 04:19 pm Aug 26 2006
by motofox2006
Im interested but are the springs your on about on ebay or are you putting them on their and how much you looking for thanx
Posted: 03:49 am Aug 27 2006
by motofox2006
just wonder if i go with the xr springs because they are 520mm long instead of the kdx 470mm long spring when the xr springs compress will i end up with coil bind has anyone here had any problems like this
