...I was gonna put that in, too...but the post was gettin' longer and longer..and what not..and short of 'lectricity, too!
We'll tag team him into submission!!
Now then...about preload...
The OEM forks have a metal 'tube' that is used as the preload spacer. The OEM springs are about 470mm in length. The XR springs Inda mentions are usually around 520mm. Obviously, you don't put the same spacer back in. Actually, you don't want the same spacer length anyway.
Preload (as the name indicates) is the distance in mm the spring is squeezed with the forks fully extended. They need to be under some pressure, but not a whole lot. The OEM preload is in the neighborhood of 35mm..and that is silly. There is a sag setting you should shoot for (how much the bike 'gives' with you on it), but with a correct rate spring, maybe .40kg/mm in your case for a KDX in the woods, 5mm is OK.
With your new springs sitting in the fork tube (before you have refilled them with oil), put the fork cap back on the rod. You don't need to tighten the jam nut, but do thread the cap as far on the rod as it will go. Measure the gap between the top of the spring and the bottom of the cap with the rod extended. Add to that figure the amount of preload you want, then subtract the amount of space the washers will take up. Cut a piece of schedule 40 PVC 1" pipe to that length.
Example: The gap is 50mm. You want 5mm preload..add the two figures to get 55mm. The clip CM mentions is already on the bottom of the spring, but you need to figure in the two flanged washers you will put back in..they measure 3mm. So, to get a 5mm preload, you cut a piece of PVC to 52mm.
Cut it square. A miter saw does an excellent job, so does a table saw. If you cut it by hand (hacksaw or handsaw) file/sand/grind the ends to make them square, debur the ends before you assemble the spacer in the fork.
Capiche?
Preload options vary as do oil levels. A well chosen one may be different from someone else's..doesn't mean it's wrong. I used 5mm partly for ease of example. That IS suitable for a correct rate spring. I ran 3-5mm in my OEM forked XR sprung setup.
BTW...I
think what CM is referring to at the end is the threading of the
fork tube onto the cap. Yes,
hold the cap and
thread the fork tube.
WHEW!! Good thing I had JUST enough watts to get that last part in there!!
So, of course I have to add summore blather....and some whatnots!!
There is a bit of an oddity with the rod/jam nut/cap that is a good thing to be aware of.
Start with the take-apart. You have your spring holder in place, wrench on the jam nut, wrench on the cap. The
first thing loosened is the jam nut
against the cap. Good. A bit of 'oomph' may be required. As you turn the cap, notice that it is NOT unthreading, but the jam nut is moving DOWN the rod. You get to a second 'sticky' spot when the jam nut gets to bottom of the threads. NOW you 'oomph' the cap loose..and start threading it UP (and off) the rod.
When you put it back together, the same thing happens. The first 'sticky' is when you UNJAM the jam nut from where it was forced against the end of the threads on the rod when you took the thing apart. Then it's easy for a bit while the jam nut threads up toward the cap,
then it gets to the second 'sticky' when the jam nut hits the cap. Tighten to spec..which is a figure that escapes me at the moment. 20psi or so?
..that's a joke...
**edit** (again..I kanna hep it!!)
WHAT does that spring holder tool look like? Well, if you use an open end wrench it looks an awful lot like a wrench. If you
make yur own tool, it just might look like this...cut out of a piece of sheet metal:
