Not alot of throw on the throttle sleve ?
Posted: 06:50 pm Jun 16 2006
by beeds3000
My two buddies bikes have like "2' - "3 " when you you twist back the throttle to full throttle, but on my bike with a new throttle cable it goes from idle to full throttle in just like a "1" of twist doesn't seem normal is there a way of adjusting this ???
Posted: 07:26 pm Jun 16 2006
by marco220
This may sound simplistic, BUT..... are you sure you have the right cable? And is routed the same as the one that came off??
Posted: 08:04 pm Jun 16 2006
by beeds3000
Ya Motion pro from bike bandit
Posted: 08:14 pm Jun 16 2006
by Indawoods
I think closer to 1 1/2" should be about right.
I think the KDX is forgiving enough where it won't hurt you.
What kinda bikes do your buddies have?
Posted: 08:33 pm Jun 16 2006
by beeds3000
honda cr 250, KX 250
Posted: 09:06 pm Jun 16 2006
by marco220
Inda's right on the measurement... 1 1/2" or so. Maybe you can loosen the freeplay adjuster for a little extra slack to feel a little better in your hand.
Posted: 01:56 pm Jun 17 2006
by Bailey28
I'm in on this poll, I like hardly any slack, maybe just enough, 1-2mm slack. I find that my wrist and forearm get tired with too much twist motion. Heck if they offered a 60 degree quick throttle, I'd be the first in line.
Posted: 05:30 pm Jun 19 2006
by canyncarvr
The answer to this:
re: 'is there a way of adjusting this ???'
is..
No.
With a given throttle tube the amount of movement required from the start of the pull (slide moving) to the end (WOT) will be the same.
Posted: 06:13 pm Jun 19 2006
by Indawoods
I had a Magura throttle tube that was adjustable between 1/4 and 1/2 throttle that I put on the KTM... seemed to give me more control. I think they may still sell them somewhere.
It worked on a pully size system... the smaller pully was for 1/2 and the larger was for 1/4....
Posted: 06:41 pm Jun 19 2006
by canyncarvr
I haven't looked for the KDX, but there are a number of aftermarket tubes that come with either different ratios or are 'adjustable' in some way.
There certainly is a way of 'adjusting' it if that means DO something about by replacing/re-engineering stuff...but there is not an adjustment to be done to/with the OEM tube..notwithstanding freeplay. But that adjustment doesn't change the amount of twist required.
