91 kdx 200 rear wheel spacing?
Posted: 04:37 pm Apr 28 2026
by Bri-man31
So my father in law bought this bike brand new and used it on the ranch for years. Then other family members used it and beat the crap out of it. Rode it like they stole it! There has been very little maintenance done on it.
So I have been fixing it up. Got it running. Had to get a new used rear hub. Had to get new spokes. Getting it all back together and there is a gap in the rear wheel spacing. If I push everything to one side there is a 1/8 inch gap for things to slide around. Am I missing a spacer? There were two spacers, one one each side.
Also the rear brake looks like it has been smashing into the swing arm for a while. Any thoughts on that?
I would appreciate any help.
Thank you!
Re: 91 kdx 200 rear wheel spacing?
Posted: 06:35 am Apr 29 2026
by Chuck78
Ouch.... The rear brake caliper mount interface with the swingarm is likely very worn out, with the aluminum deformed on the caliper mount or the swingarm, or quite likely both portions. That is why the caliper's brake line banjo bolt is able to rotate forward and collide with the top of the swingarm, leaving indentations in it.
As far as the spacing, I would compare the replacement hub width to the previous hub's width to make certain you have the same part for starters. A little bit of a gap is normal, but while the axle nut would close that down, that's excessive. The swingarm itself could also be a bit tweaked, and perhaps it was negligently ridden around with the axle nut loose, which could have spread the swingarm apart a but as well as hammered the brake stay portion of the caliper into the swingarm interface lug. Lots to investigate here in person still.
Best of luck, you've come to a great place for assistance, but further in-person investigation needs to take place to get this sorted.
Posted: 07:35 am Apr 29 2026
by Bri-man31
I will take it apart and post some pictures of the brake and swingarm.
I will also do some measurements of the old hub compared to the new hub.
Thank you Chuck78
Posted: 07:08 pm Apr 29 2026
by pumpguy
On that replacement rear hub, is the internal spacer that goes between the 2 bearings present?
If not, the bearings will lock up when you tighten the axle nut.
Posted: 10:23 am May 01 2026
Is the 2 mm thick washer on the right side missing?
https://www.partzilla.com/catalog/kawas ... 3/rear-hub
Working on stuff after someone else continues to be the light that makes us all glow inside... bright like the center of the sun.
Posted: 08:37 pm May 08 2026
by Bri-man31
Sorry it has taken me a minute to get updates.
After checking, I am missing the 2mm washer. Does anyone know if it has to be that exact washer or can any 2mm thick washer work?
How would I check if the brake caliper slot thing is worn?
I will attach pictures.
Any help is much appreciated.
Thank you!
Posted: 02:05 pm May 09 2026
by Chuck78
Bri-man31 wrote: 08:37 pm May 08 2026
OUCH!
Yes, your rear caliper hanger's interface slot to the swingarm is far beyond worn out....
You can find them used on eBay with and without the rear caliper, and potentially even new from Kawasaki or New Old Stock.
Also, the Scott's Performance Shark Fin heavy duty rotor guards are integrated into a billet CNC machined caliper hanger replacement as well... but at a hefty price tag of $150.
https://www.scottsonline.com/Product_Pu ... BI_ID=2164
