Is this what I need?
- KanuckKDX
KanuckKDX
'01 YZ426F son's
'02 XR400 still for sale
'04 KTM 450exc it's all about the e-start
						'01 YZ426F son's
Yep... besides a wheel and axle....
- m0rie
That would be a nice setup.  For E series bikes you'll need to get a newer 95 KDX brake caliper or the matching KX caliper.  There will be minor rubbing between the right side fork and radiator cap.  Also the forks will barely touch the tank at full lock on either side.  I'm working on spacing the top of the right radiator back about 1/2" which should solve the radiator cap rubbing.  The forks don't touch the tank enough to be worried about but you can use a heat gun to dent in the tank or add some material to the steering stops to keep the forks from touching.
- KanuckKDX
So I have read the sticky and a few other threads but I still need spoon feeding.
I can find wheels and brakes for KX 125, 250 and 500. Which size bikes and which years should I consider? eBay has a good selection.
As far as getting it together, I see I wil need to be patient and may need some mods at a machine shhop, but it looks possible.
My KDX is like the others, a little soft for an adult male and I wonder if the front end conributes to the sense that the rear end won't stay on the ground as well as it should. Of course all I compare it to is the CR250, the RMX250 and the XR400.
Thanks.
TEDD
Thanks.
TEDD
KanuckKDX
'01 YZ426F son's
						'01 YZ426F son's
- m0rie
Its more than possible Tedd, I just finished doing the KX fork swap on my 89 and its night and day the difference it makes.  Be prepared though, once you get the forks on and see what its like to have a front end that actually works correctly you'll realize how crappy the rear end works.  Thats the next thing to "fix" on my list and you'll be in the same boat once  your done with the front.
96-98 KX125 or KX250 for the front wheel and axle will work without mods. Same for the brake caliper or a 95+ KDX brake caliper. The only other mod that you'll need to do for the front end will be having the KDX stem pressed out of your KDX clamp and into the KX clamp. Depending on the fit you might need to have the clamp knurled before the stem is pressed in. The machinest should be able to determine if its needed. Your existing brake line will work, however you'll have to make a clamp to hold the brake line to the fork guard. Zip ties work well. You will also need to make a spacer from some washers to raise the top clamp about 1/4" and a little shim stock to shim the top of the KDX stem in the top clamp hole.
- Ryan
