H Series with KYB SSS Forks from 16' YZ250F
ebulic19
Country: Ohio United States
Been thanked: 2 times
Post by ebulic19 »
Hello all,
I recently purchased a full front end off of a 2016 Yamaha YZ250F. Included in this was the triple clamps, forks, wheel, and full front brake. I have begun to mock things up and ended up purchasing the steering stem bearings with the assumptions that I will not be pressing in the OEM KDX stem.
Based on my knowledge the bearing dimensions are as follows.
YZ250F
Upper bearing: 28x52x16 mm
Lower bearing: 30x52x16 mm
KDX 200
Upper bearing: 25x47x15 mm
Lower bearing: 30x55x17 mm
This lead me to purchase the following bearing sizes.
Upper bearing: 28x47x15 mm (off of Amazon from a Chinese retailer)
Lower bearing: 30x55x17 mm (NSK bearing)
Upon looking at the YZ stem in the KDX head tube a little closer, it appears that it is slightly longer than the KDX stem. With that I have read on here that there is mainly one option, being option one below. Has anyone tried options two or three below?
1. Shim the upper bearing race slightly higher to get more crush to adjust steering movement. This appears to be done by either putting a shim on top of the bearing or underneath the outer race, if I am thinking of it correctly.
2. Take a 28 x 1.0 metric die and tap threads a little lower on the aluminum stem to where the steering adjustment nut then puts enough pressure on the upper bearing. Coupled with this I would run a concial washer on top of the top triple clamp, so I do not bottom out the flange nut on the top triple before getting the nut torqued to spec.
3. Press the stem slightly lower in the bottom triple clamps, effectively lowering the overall stem length to where it is closer in total length to the KDX stem.
Any insight is appreciated. :pop:
Has thanked: 126 times
Been thanked: 59 times
Re: H Series with KYB SSS Forks from 16' YZ250F
Where is the upper bearing steering stem position bottom limit located at in relation to the bottom of the actual bearing installed in the frame as stock, with the updated adapter bearing size? If it is anywhere in the vicinity of the bottom of the bearing give or take 2 mm, I would run it as is, and if you needed additional stack height on top, which from memory should only be a few millimeters, I would add an extra spacer above the bearing and seal on the steering stem, in order to get the lock nut to clamp down properly.
The only reason I would shim the upper bearing outer race higher in the frame with a custom shim would be if I were using the Japanese NSK (or All Balls version) 30x47x12 bearing where the KDX frame itself is 15mm tall, which one other's wise results in the bearing being 3mm down in the hole since it's a skinny profile height bearing.
I have a couple of these bearings for my swaps, the 30x47x12 NSK bearings... Pyramid Parts stoped selling the kit that I bought that includes the seal and a 3mm spacer, so that's unfortunate, but the bearing is still available from them. I'll have to look and see as the seals came from the USA and bearing from japan, even though pyramid Parts is from the UK somewhere. So perhaps I can get a part number off of the USA made seals and just get those separately. Cutting a spacer in my lathe there's no problem. Finding the time to work on fun projects is the only problem for me these days!
All Balls sells that kit readily, 30x47x12 with spacer and seal, but for your application, you would still need a custom machine to match up to the 28mm stem, a bearing reducer bushing that is 1 mm wall thickness with a large flange on the top like a washer to sit on top of the bearing and seal and keep the spacer sleep from sliding down on the stem into the frame.
ebulic19
Post by ebulic19 »
Update - I ended up getting the bearings in that I had ordered. The outer races pressed into the KDX stem without issue. I also got enough crush on the upper steering bearing without having to tap more threads onto the steering stem itself. I ended up modifying some of the upper bearing seal off of my KDX to cover the new upper steering bearing. The bottom seal sat on top of the bottom triple without issue. I also included washed underneath the flange nut that tightens the triple clamps down as I was bottoming that nut out. Forks mocked up well but appear to be way too long. Potentially needing to shorten them internally by about 1 to 1.5 inches. I also will need to weld on a steering stop tab as the lower triples miss the stops by being slightly lower than the KLX triples.
So far this appears to be a viable option based on stem length.
IMG_1438 2.jpg (3.96 MiB) Viewed 94460 times
Perhaps one of these might correct the steering stop position and range? Or fabricating something very similar. Mounted upside down, it would lower the stop location if that's needed .
https://trickeng.com/product/kx125-250- ... p-adapter/
ebulic19
Post by ebulic19 »
Do you have experience with that product? Is that to stop any potential chipping of the aluminum stops via the steel steering tab on the front of the frame?
ebulic19 wrote: 08:58 pm Sep 03 2025 Do you have experience with that product? Is that to stop any potential chipping of the aluminum stops via the steel steering tab on the front of the frame?
I have not purchased this and I likely would just fabricate my own to my exact needs and specifications as I have some basic manual machine shop equipment in my home shop, but this stop is made I believe for those fitting modern KX450 forks onto a KX500 frame. The KX500 frame will have very similar steering stops as the KDX and KLX. KLX300 triple clamps on a KDX 220 / 200H come up just a slight bit short, but are almost perfect. The fork does hit the gas tank.
So I would imagine this would be pretty close or maybe too much and need ground down. I'm not sure if you could find out the dimensions of this and compared to what your bike needs, but this style of stop fixes a lot of problems.
ebulic19
Post by ebulic19 »
Chuck78 wrote: 01:37 pm Sep 04 2025
Thanks for the suggestion Chuck. I ended up ordering the stop... we will see how it works. It is a pretty novel idea. I am thinking I am going to have the forks internally shortened by Corey at Protune, and probably revalved/rebuilt.
ebulic19 wrote: 06:53 pm Sep 06 2025
Corey at Protune Suspension does an awesome job, in my opinion the best in the region despite the amount of pro racers / pro race teams who use one of the other two in Southeastern Ohio. I feel that the others are more focused on valving for fast young racers in their 20's and skip over that initial plushness that casual trail riders, hard enduro riders, and singletrack riders are after...
I didn't realize you were from Ohio? Where do you ride at primarily?
If that stop doesn't work out for you, I will machine a few custom spec versions of it this winter, of you can get by until then.
At present, I hardly can find a y time to even get out and ride unfortunately... Hopefully by late season I'll get a few more good rides in
ebulic19
Post by ebulic19 »
Chuck78 wrote: 07:51 am Sep 07 2025
Totally agree... Corey is quick to respond and really works with you. I am mainly riding at Perry and Lightning. I have access to private acreage to ride nearby. I've been hoping to get out to Wellsville before the season is over. Still have not ridden there yet.
That'd be great. I am hoping Trick ships me my stop here soon. After the forks are shortened I think I should be good. I also want to get a black rim for the back to match the front, given the YZ is black as well.
We may make it out to Wellsville yet this season, I'll let you know if we do.
Wellsville is a bit like Perry State Forest, in that you really need to know someone who knows the locations of the single tracks in order to easily find anything to ride other than Jeep and side by side trails, & the very well known gnarly hill climbs. Interestingly enough, some trail users there have added the locations of the most popular of the hill climbs onto Google Maps as some sort of hiking routes or ski lift routes or something like that, some technical loophole where they were able to literally put them on the map! Look up The Forbidden Zobe Campground on Google Maps and select the terrain view map layer, and also switch back and forth to the satellite map, you'll see the hill climbs labeled at certain zoom levels. Scooby, Boat Dock, Crazy Horse etc.
My buddy lives about 45 minutes from there near Akron, he knows Wellsville somewhat decently, enough to get us around, and has learned a fair bit of the single tracks there from his high level racer buddies he works with at Kenda. A lot of the trails they take him on involve riding up some gnarly stuff including some very steep slippery waterfalls to get into the single tracks, so he didn't guide us on the full tour because it would have guaranteed half of us flopping our bikes down hard!
I have some write-ups on here about Wellsville with a few photos:
viewtopic.php?t=26097
The yellow arrows I sketched on here take you from the green dot which is the campground, and down a big power line clear cut hill climb that's nearly half mile down to the creek (there's a picture of my bike looking up from the upper section which is a fairly technical medium steepness rocky climb), and then hangs a right into the creek called Rocky Run. The famous Crazy Horse hill climb and one other really intensely steep and tall hill climb are both off of Rocky Run. The creek is really good fin rock riding, and there are several really technical trails that come up out of that if you look carefully enough and explore a lot.
I think the track headed south Southwest out of the campground on my GPS screenshot is a single track that starts right behind a permanent cabin built towards the end of the campground that's adorned with motorcycle tires and other bike trinkets, I suspect it's maybe one of the campground owners unless it's a semi-permanent resident camper's spot. Hit that. A lot of others there are ATV trails we were connecting with, but I believe a few of those other tracks might be singles as well. Like I said, your best linking up with someone who knows how to get to all the good single tracks there and is going to be able to guide you on routes that are within your choice of technicality and skill level.
We ride at Wayne National Forest & Perry State Forest a fair bit, but this year has been too busy for me and June and July far too hot to get much riding in, sadly.
I might have even seen you around Perry before, but I usually try & go out of my way to talk to anybody with a KDX where possible unless I'm with a group that's moving.
I did chat briefly with someone on a KDX at the trailhead last time I was at Perry 4-5 weeks ago, but I think it might have been an E-Series. My KDX has purple shrouds and graphics with the KX checkered flag background and purple seat, hard to miss that one.
ebulic19
Post by ebulic19 »
Yeah please do let me know, I'd be interested. My KDX isn't my primary ride, so it is unlikely you ran into me at Perry. If you ever run into a real tall guy on a Husky 300 than that's me.
Once I get these forks sorted I might ride the KDX a little more frequent. It really requires more skills to ride relative to the 300, IMO.
ebulic19
Post by ebulic19 »
I ended up getting the forks mocked up in the chassis. It is apparent that I will need them shortened by quite a bit. The steering stop from trick engineering worked well, however, I needed to grind it down to allow for full turning radius. I think I will grind the stop slightly more after I get the shortened forks back from Protune. It looks like quite the chopper right now... ready for desert racing LOL
Forks with wheel
Forks with wheel
Hey, thanks for the update! I'm glad to hear that Trick Engineering steering stop worked out to be plenty enough material! It's better to have to file off a little bit, than to not have enough to begin with, that was my biggest fear with my recommendation, although I did give caution to that area of concern!
ebulic19
Post by ebulic19 »
No problem! it came together really nicely. Had the forks shortened about 1 inch by Corey and revalved... did a little spin around the backyard today and it feels very capable, but I may have to file the trick engineering stop slightly more to help with steering radius. Either that, or grind off some aluminum from the stopping lugs on the YZ triples. I had the same problem with not enough steering radius when I had the KLX forks on the bike.
I am hoping I can get my new plastics in from UFO before the Crow Canyon event in November and maybe ride it there for the first time. If you don't go to that, I highly recommend, some really good single track. I think the AA loop is about 12 miles. They also have free KTM demos which is always fun.
ebulic19
Post by ebulic19 »
Here is the finished project. The only other to do is potentially get some KDXRider.net stickers for the front fender, figure out the headlight situation, and get a rear black rim mounted.
KDX .jpg (4.57 MiB) Viewed 84150 times
SpruceItUp
Has thanked: 77 times
Been thanked: 26 times
Post by SpruceItUp »
ebulic19 wrote: 08:47 pm Oct 09 2025 Here is the finished project. The only other to do is potentially get some KDXRider.net stickers for the front fender, figure out the headlight situation, and get a rear black rim mounted.
Looks amazing! Glad you got it finished. I bet it rides great!
Speaking of KDXRider.net stickers, I'd love a couple for my E series, too!
92 KDX200
04 CRF450R
05 CR125R
ebulic19
Post by ebulic19 »
SpruceItUp wrote: 02:25 pm Oct 10 2025
I think there are a couple members potentially pulling together some bulk orders. So be on the lookout in the forums.
