Kdx idle is very high although I don't seem to find an air leaking
Antii_200
Country: Import from Sweden
Post by Antii_200 »
My kdx idles very high, the idle screw doesn't do much if I turn it any less it just turns off, so basically it has to idle at like half throttle or stalls :hmm:
kdxdazz
Country: thailand
Re: Kdx idle is very high although I don't seem to find an air leaking
Post by kdxdazz »
When you say can't find an air leak , how are you checking?
Antii_200
Post by Antii_200 »
kdxdazz wrote: 01:48 pm Apr 20 2025 When you say can't find an air leak , how are you checking?
I checked the intake manifold for cracks and holes, and sprayed it's area with starting fluid, nothing changed- I found the culprit though, the air/fuel screw came loose and it was running lean
Hey, all right! Cheap AND quick. Good job.
