87 mikuni rejet
87KDXfan
87 mikuni rejet
Post by 87KDXfan »
So I've recently performed some fuel system mods on the 87. DG pipe, new badly needed intake boot, new boyesen pro series dual stage reeds, and bumped the pilot jet from a 25 to a 32.5. As a mechanic of 30 years who owns jet drills, I... Clearanced the 320 main jet a whisker (blue point jet drill set). However as a precautionary measure I ordered 330, 340 and 350 main jets. In the event my "clearancing" wasn't working out, I'd have the other jets to fall back on. Funny enough, just after the jet clearancing, I opened the destructions for the new reeds informing me that it's going to run a bit ritcher :razz:
After discovering this, I relocated the needle clip one slot higher (leaner) hoping to compensate for my ways.
Today was the acid test. Went out in the rain and twisted on her in the woods. I noticed a few things that were new.
First - I noticed that after riding on a trail or two and coming to a stop, she seemed to idle down and die as though it loaded up, which I'm thinking is the pilot as I bumped it up seven and a half sizes.
Second - I noticed a new lean spot going from mid throttle to full onion. I may need to bring the needle up back to where it was, put in a 330 main and bring the pilot jet back down to planet earth.
Anyone have a similar experience or any advice? Thanks in advance!
Has thanked: 67 times
Been thanked: 20 times
Re: 87 mikuni rejet
Why did you jump so high on the pilot? :-) I think I would have waited on drilling out the main. Temps are going down.
87KDXfan
Re: 87 mikuni rejet
Post by 87KDXfan »
May have had something to do with the song that was playing as I worked, Sky Pilot
87KDXfan
Re: 87 mikuni rejet
Post by 87KDXfan »
After coffee time is over, I'm going to get it unloaded from the truck and look at the plug, pull the carb and scale the jets down a tickle.
Re: 87 mikuni rejet
Let us know how it turns out.
87KDXfan
Re: 87 mikuni rejet
Post by 87KDXfan »
It's improved. I need to bring the slide needle height up a notch or two, mid range could be better.
It did something on the test ride that was new to me, riding along if I pull in the clutch and rev it up (not under load), it revs to a certain point then just falls off and won't go further up in rpms. May be related to the needle height.
Re: 87 mikuni rejet
Going from 25 to 32.5 is three jets sizes.
How does it run at full throttle?
87KDXfan
Re: 87 mikuni rejet
Post by 87KDXfan »
Under load it's ok. To me it seems like keeping it on the pipe while pulling a slight grade at high speed (like on a forest service road) is a bit of a challenge and requires a few downshifts. Feels slow but I need to keep in mind im about 210 lbs and it's a 200 cc engine. It just seems like it can be better. I noticed it cut out when I cracked it open to a high rev (clutch in, no load)
87KDXfan
Re: 87 mikuni rejet
Post by 87KDXfan »
Would it be advisable to step the pilot jet and main jet up the same amount, like if I went 2 steps higher on one, go 2 steps higher on the other as well or is it all circumstantial?
Re: 87 mikuni rejet
Get the pilot jet sorted first, then the needle, then the main. You'll never get the main right with the wrong pilot and needle.
At full throttle, the pilot, needle and main are all working together.
87KDXfan
Re: 87 mikuni rejet
Post by 87KDXfan »
Have you ever had an overly enriched condition to where you rev the motor and it cuts at high rev? I associate that with being lean but I've been wrong before
Re: 87 mikuni rejet
not that I can think of
Has thanked: 10 times
Been thanked: 49 times
Re: 87 mikuni rejet
87KDXfan wrote: 10:27 am Nov 02 2024 May have had something to do with the song that was playing as I worked, Sky Pilot
"Heart" this song. Back in the stone age, I played this song frequenlty from a 45 RPM vinyl record on my commercially broadcasted radio program. I still listen to the recordings by the Animals, especially on certain long distance drives in my MINI in SoCal. This includes the entire "Love Is" album.
