Page 1 of 2
250 starting problems
Posted: 12:44 am Jul 11 2024
by asiaexpat
Very difficult to start my kdx..once its warmed up starts easily. I live in warm climate. Any ideas on what might be wrong? Recently changed to a 33mm chinese carb as the 35 mm original needs repairing and I have not found a repair kit yet.
Re: 250 starting problems
Posted: 02:52 am Jul 11 2024
Welcome to kdxrider.
Assuming everything else is OK, carb or reeds would be where I started.
Posted: 03:02 am Jul 11 2024
by Broken Wrist
Was it difficult to start cold prior to installing the Chinese Carb ??
Posted: 11:20 am Jul 11 2024
by Molly's 70
My guess is that Chinese carb is a pile of doo doo.
Posted: 11:34 pm Jul 11 2024
by Chuck78
Chinese carbs have poor quality control. Seldom are they going to meet the required precision to get the job done as good as proper OEM spec carbs.
Posted: 12:28 am Jul 12 2024
What is the issue with the OEM carb?
How did it run before the OEM carb went bad?
Posted: 08:03 am Jul 13 2024
by asiaexpat
KDXGarage wrote: 12:28 am Jul 12 2024
with oem carb==when i filled gas tank gas just started pouring out of the the overflow hose. But it strted easily with oem carb. Basically i took bad advice and got the chines carb and was told my oem needed a repair kit which I cant seem to find.
Posted: 08:04 am Jul 13 2024
by asiaexpat
Molly's 70 wrote: 11:20 am Jul 11 2024
sounds right--30$
Posted: 08:05 am Jul 13 2024
by asiaexpat
sorry for the slow responses--i didnt get any notifications
Posted: 10:59 am Jul 13 2024
by Chuck78
You just need a float needle and float bowl gasket for the OEM carb, and definitely a good idea to change out the jet block gasket with a genuine OEM Keihin part, not aftermarket. It's not shown on the Kawasaki parts diagrams, but it's there. You just have to order it from Sudco, Jets R Us, or JD Jetting to get a guaranteed genuine Keihin part.
Apologies if you've said you already replaced the jet block gasket, I didn't have time to read the thread again.
The float needle or a gummed up seat for the fooat needle, along with proper float height adjustment, I believe 18mm is the accepted spec vs OEM calling for 16mm, & your OEM carb issue will hopefully be resolved.
Posted: 12:28 pm Jul 13 2024
by bufftester
Yeah, if you turn on the gas and gas just starts pouring out the overflow you have a stuck float, easily cleaned up with a carb clean/rebuild. Likely that's all that's keeping you from running your OEM carb. The Chinese clones are $30 for a reason
Posted: 06:02 pm Jul 13 2024
Check for the rubber cone not sealing against the face.
Posted: 02:28 am Jul 14 2024
by asiaexpat
Chuck78 wrote: 10:59 am Jul 13 2024
Im not sure what kit to order. the markings on my oem carb are PJ 150AFH
Posted: 02:24 pm Jul 14 2024
Can you post a picture of what you are seeing so we can see it too? Instructions in my signature.
Posted: 10:54 pm Jul 14 2024
by asiaexpat
KDXGarage wrote: 02:24 pm Jul 14 2024
My local mechanic says I need new float bowl gasket. I would prefer a full repair kit. Not sure which one to buy.
Posted: 11:43 pm Jul 14 2024
Did that bike come stock with a PJ carb? In the USA, our KDX's had the PWK from 1988 onward.
Posted: 01:07 am Jul 15 2024
by asiaexpat
KDXGarage wrote: 11:43 pm Jul 14 2024
I dont know..bought it second hand..Imported into thailand from Japan I believe
Posted: 03:52 am Jul 15 2024
What year and exact model is it?
Do you have a VIN or frame number you can post? Thanks. A place called impex has parts diagrams.
Posted: 06:33 am Jul 15 2024
by Chuck78
Is this a KDX250SR?
The parts may be different between an offroad model PWK36 & an SR street legal model, but the type of parts needed will be the same,float needle and float bowl gasket, perhaps jet block gasket.
Posted: 11:02 am Jul 15 2024
by asiaexpat
Chuck78 wrote: 06:33 am Jul 15 2024
Is this a KDX250SR?
I dont know if this sr. the graphics are different than the sr's that I have seen here. But it is street legal..turn signals etc..
