Anodized aluminum chain adjuster snail cams!
This is pretty trick, a company making some small batch blue or purple anodized lightweight aluminum KDX snail cam chain adjusters!
https://youtube.com/shorts/yFT891uAvMU
Blue was the first batch, they're doing a purple batch in a few weeks!
https://crucial-gear-llc.odoo.com/shop/ ... =2#attr=28
Re: Anodized aluminum chain adjuster snail cams!
Perhaps someone can answer my question here - my '99 came with an OEM rear axle with the snail cam adjuster welded to the non-threaded side of the axle.
My '97 (which may have had a KLX300 rear wheel on it, as prev.owner had leftover KLX forks on it, and was upgrading his KLX with supermoto wheels) has the snail cam adjusters both loose, not welded to the non-threaded side of the axle.
Did Kawasaki jump back and forth on this, or was this a KLX thing?
Ultimately, I'd like to get a batch of titanium KDX rear axles made up, problem solved! No fronts, as most people who'd drop big $$$ on titanium hardware would also be upgrading to a better fork, and most modern bikes' forks will have titanium front axles available already...
Pretty cool that they are doing that!
Thanks for sparking my curiosity to check out the following! I had no clue there were 3 different 1995+ (USA) rear axles.
Here's the 1999 info on the rear axle. My opinion is that the welded cam adjuster equals "quick release" for racing. Two loose ones equals more trouble when quick changing wheels. If it is at the house, then it won't matter much.
This Kawasaki 41068-1340 AXLE,RR fits the following models and components:
Kawasaki Motorcycle 1997 KDX200 - KDX200-H3 Rear Hub
Kawasaki Motorcycle 1994 KLX650R - KLX650-A2 Rear Hub
Kawasaki Motorcycle 1995 KDX200 - KDX200-H1 Rear Hub
Kawasaki Motorcycle 1998 KLX300R - KLX300-A3 Rear Hub
Kawasaki Motorcycle 1994 KLX250R - KLX250-D2 Rear Hub
Kawasaki Motorcycle 1995 KLX250R - KLX250-D3 Rear Hub
Kawasaki Motorcycle 1996 KLX250R - KLX250-D4 Rear Hub
Kawasaki Motorcycle 1996 KDX200 - KDX200-H2 Rear Hub
Kawasaki Motorcycle 1997 KDX220R - KDX220-A4 Rear Hub
Kawasaki Motorcycle 1997 KLX300R - KLX300-A2 Rear Hub
Kawasaki Motorcycle 1995 KLX650R - KLX650-A3 Rear Hub
Kawasaki Motorcycle 1998 KDX200 - KDX200-H4 Rear Hub
Kawasaki Motorcycle 1998 KDX220R - KDX220-A5 Rear Hub
Kawasaki Motorcycle 1996 KLX650R - KLX650-D1 Rear Hub
Kawasaki Motorcycle 1999 KDX200 - KDX200-H5 Rear Hub
Kawasaki Motorcycle 1999 KLX300R - KLX300-A4 Rear Hub
Kawasaki Motorcycle 1993 KLX650R - KLX650-A1 Rear Hub
Here's 2000 KDX200:
This Kawasaki 41068-1341 AXLE,RR fits the following models and components:
Kawasaki Motorcycle 2001 KDX220R - KDX220-A8 Rear Hub
Kawasaki Motorcycle 2002 KDX220R - KDX220-A9 Rear Hub
Kawasaki Motorcycle 2002 KLX300R - KLX300-A7 Rear Hub
Kawasaki Motorcycle 2002 KDX200 - KDX200-H8 Rear Hub
Kawasaki Motorcycle 2004 KDX200 - KDX200-H10 Rear Hub
Kawasaki Motorcycle 2001 KDX200 - KDX200-H7 Rear Hub
Kawasaki Motorcycle 2000 KLX300R - KLX300-A5 Rear Hub
Kawasaki Motorcycle 2000 KDX200 - KDX200-H6 Rear Hub
Kawasaki Motorcycle 2000 KDX220R - KDX220-A7 Rear Hub
Kawasaki Motorcycle 2003 KLX300R - KLX300-A8 Rear Hub
Kawasaki Motorcycle 2004 KLX300R - KLX300-A9 Rear Hub
Kawasaki Motorcycle 1999 KDX220R - KDX220-A6 Rear Hub
Kawasaki Motorcycle 2004 KDX220R - KDX220-A11 Rear Hub
Kawasaki Motorcycle 2003 KDX220R - KDX220-A10 Rear Hub
Kawasaki Motorcycle 2003 KDX200 - KDX200-H9 Rear Hub
Kawasaki Motorcycle 2001 KLX300R - KLX300-A6 Rear Hub
Here's 2005:
This Kawasaki 41068-0014 AXLE fits the following models and components:
Aftermarket Parts Drive Axles
Kawasaki Motorcycle 2007 KLX300R - KLX300A7F Rear Hub
Kawasaki Motorcycle 2007 KLX250S - KLX250H7F Rear Hub
Kawasaki Motorcycle 2006 KDX200 - KDX200H6F Rear Hub
Kawasaki Motorcycle 2005 KDX200 - KDX200-H11 Rear Hub
Kawasaki Motorcycle 2006 KLX300R - KLX300A6F Rear Hub
Kawasaki Motorcycle 2006 KLX250S - KLX250H6F Rear Hub
Kawasaki Motorcycle 2005 KLX300R - KLX300-A10 Rear Hub
Kawasaki Motorcycle 2005 KDX220R - KDX220-A12 Rear Hub
KDXGarage wrote: 06:10 pm Jul 02 2024 Pretty cool that they are doing that!
Here's 2000 KDX200:
Here's 2005:
Wow... Very interesting!
Mine are a '99 (welded snail cam) & '97 (not welded,so I suspect this was from previous owner's KLX300 - which must've been a 2000+... The axle spacers also were about 1mm or 2mm thinner overall vs the fitment on my '99, so perhaps also KLX items...
Thanks for digging this info up!
The 95-06 KDX's are generally all identical and 99.5% parts interchange, but there are a lot more subtle differences than we realize!
Hey. You are welcome. Thanks for your great info.
I know my '87 front axle has the little grab bar on it for what I think are quick change purposes.
I wonder if that store would sell just 1 for the right side for those that have the earlier axles.
EDIT ADD-ON: The service manual versions had some tiny changes also. For example, rear axle nut torque was increased from 72 foot-pounds to 80 foot-pounds.
KDXGarage wrote: 03:24 pm Jul 03 2024
They do offer a service to machine off your stock welded on snail cam adjuster and re-plate the axle in zinc or nickel plating, it's on the webpage for the adjusters
Re: Crucial Gear shop…
Interesting that the aluminum snails are currently their only featured product currently, must be a brand new website. They have some nice machines.
If they are looking for product ideas Chuck, maybe you could suggest to them machining power valves for H model bikes? Also clutch actuators are hard to find… and front wheel spacers for swapping out the odometer piece for race bikes… and the special axel for using KDX front wheels in KX forks!
We can definitely provide ideas for more products!
As far as aluminum snails go, they’re mighty pretty but I a wonder if they handle the beating my old steel ones get in the WV rocks we have?
Same vendor offers off-spec cams for 50% less! Link below. Their website says they are fully functional. I like a bargain!
https://crucial-gear-llc.odoo.com/shop/ ... 20#attr=31
billie_morini wrote: 08:34 pm Jul 31 2024 Same vendor offers off-spec cams for 50% less! Link below. Their website says they are fully functional. I like a bargain!
I'm still waiting on the purple batch! 💜
They offered me a set of blue blems for free due to my wait time after multiple inquiries, but I passed up on the offer, as I only am interested in purple!
