I know this has probably been discussed before but on rear tire sizes, I know it effects the final gear ratio. So how would a 110/100/18 effect the final ratio from a 120/100/18? Would it have less top end? I'm shopping for a new rear tire for my vintage junk, and Most of these tracks I rearley see 4 gear, and alot of tight flat turns. I'm looking at the Kenda Trackmaster II. I run one on the blue bike and it's awsome. Does good in mud and dry conditions and very durable. So here's my options:
100/100/18
110/100/18
120/100/18
I'd like to figure out what the first two numbers represent on the tire size. I know the last number is rim size but the first tow numbers one has to be width and the other sidwall height or outside diameter or something like that.
Rear tire sizes.
Width/Height to width/rim size
The middle number is aspect ratio... as in percentage. 100 wide and 100% high as it is wide is how I know to read it.
100/100/18 will be narrower and shorter than the rest. Giving it a lower profile and give you greater torque and less top speed.
- quailchaser
I did some research on the difference (% wise on height) on the tire sizes two years ago or so...when I was changing the gear ratio on the KDX. I believe it worked out that a 110 is ~5-6% taller than the 100. Same for the 120 to the 110. I believe that worked out to be about 1 tooth different on the back to keep approximatley the same gear ratio. It's been a long time...so I may be off .5% or so....
Robb
'02 KX250
PW80 for the Gman
AMA
Off Camber M/C
BRC
AZOHVC
'02 KX250
PW80 for the Gman
AMA
Off Camber M/C
BRC
AZOHVC
110 is narrower width than the 120, 100 is the same height
I run either a 110/100 D756 or a 110/90 D952. I have to try the D952, but pattern appears to be the same, except the knob cuts are a bit different
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
2005 KLX 125L (SONS)
2003 KTM 50SX Pro Jr
B Senior # 254/0092
Thanks to my 2008 Sponsers:
John W Read Jr
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
