New E-series owner from Alabama
Posted: 12:54 pm Oct 26 2023
Hi there everybody, never thought I'd be a kawasaki owner (always been a Yamaha guy), but always wanted a good sporty enduro 2 stroke and heard nothing but good things about the KDX, so here I am. Recently bought an 89 with 1050 miles on it in relatively decent condition. Pipe was smashed almost flat when I bought it, so I've put am fmf fatty on it, running the stock silencer. I'm fairly dirt bike experienced, and wow, this thing rips. I haven't played with the jetting yet so it's surely running rich (figured I'd be safe for a day ride or two), but even still it is ridiculously strong all over the rev range except the very bottom. I believe the pilot jet may be clogged, as the idle screw is maxed out, so it's probably running on the needle.... but surprisingly it idles and acts normal for the most part. Plug is dark so I don't feel it's in immediate danger. It'll get a good carb clean and jetting in a month or so.
I've also made a discovery that may be of use to someone: My stock air filter was degraded and I couldn't find one locally in time for my ride last weekend, BUT I did have a spare UNI for my drz400 laying around, which looked mighty similar. Sure enough, it's almost a perfect fit! So, if you're ever in a bind for an air filter, a local cycle gear or something of that nature is pretty likely to have an air filter in stock that will work.
Anyways, glad to be here, I'm sure I can learn a lot from you guys.
-Jon
-Jon
