Mikuni jet size scale to Keihin jet size scale
85' kid
So I've got a Mikuni tmx 38mm carb on my 94 kx125 and it spits oil. I'm running a 50:1 mix and there is still oil just running down the silencer and dripping off onto the swingarm. I looked up stock jetting and it was 160 main jet and 45 pilot jet, and the stock carb was a Keihin. But the Mikuni has a 380 main and a 40 pilot. The pilot is normal but the main seems massive. Perhaps it is just a massive main jet thus the richness or is there a different jet scale that Mikuni uses as opposed to Keihin?
- Has thanked: 66 times
- Been thanked: 20 times
Re: Mikuni jet size scale to Keihin jet size scale
They do use a different numbering system.
If everything is mechanically sound, start at the pilot and air screw, then go up from there.
