Bottom End/Transmission Reassembly
Posted: 10:34 am Jan 29 2023
Fellow KDXers:
I would like advice, pointers or tips on reassembling the bottom end on my 2004 KDX200.
More specifically, How do I reassemble the transmission making sure it is in the NEUTRAL position? Like what orientation does the shift drum needs to be in?
Also what's the best procedure to seal the crankcase halfs? Last year I had excess smoke on startup. A friend said it could be seals OR incorrect sealing of the cases. I corrected the seal problem. Now I wanna be sure this step is done correctly.
Thanks!
Thanks!
