Sealing oem carb holder to reed block
Posted: 08:52 pm Nov 23 2022
by JZ05220r
I have plans to switch back to the stock reed cage as the Lectron will not work with the thicker v force reed block. I had an issue in the past with the carb holder not sealing fully to the reed block. I see that the built in o rings on the carb holder are what create the seal. I am wondering what the best solution is to be absolutely sure the reed block seals the first time around. Thanks
Re: Sealing oem carb holder to reed block
Posted: 06:28 am Nov 24 2022
by Molly's 70
I always use the factory gasket.
Posted: 12:43 pm Nov 24 2022
by JZ05220r
Molly's 70 wrote: 06:28 am Nov 24 2022
Hey, I’m talking about the area the carb holder and reed block that technically uses no gasket. Thanks and happy holidays
Posted: 10:11 am Nov 26 2022
by Slick_Nick
JZ05220r wrote: 12:43 pm Nov 24 2022
Put a very thin coat of grease on the seal lip it will allow the boot to kinda slide around a bit and help everything line up.
Posted: 05:39 pm Nov 26 2022
by JZ05220r
Slick_Nick wrote: 10:11 am Nov 26 2022
Thank you I’ll give that a go.
Posted: 07:57 pm Nov 29 2022
by kdxdazz
I went through this before too, if the o rings are damaged or flattened there is no way of sealing it, you can't just cut a gasket as the seal also holds the white plastic insert into the reed block, I tried many different combinations but in the end I bought a new carb boot, if you are able do a leak down test and spray around the carb boot to check for no leaks, I also have a lectron
Posted: 02:32 am Dec 03 2022
by JZ05220r
kdxdazz wrote: 07:57 pm Nov 29 2022
Thanks. I had a thought. Maybe I can just run a small bead of rtv around the outer o ring. The one that’s closes to the edges or the carb boot.
Posted: 12:49 pm Dec 03 2022
by SS109
JZ05220r wrote: 02:32 am Dec 03 2022
Do not use RTV in gasoline situations.
Posted: 06:11 pm Dec 04 2022
by JZ05220r
SS109 wrote: 12:49 pm Dec 03 2022
Ok i thought it was tolerant to gas.
Posted: 07:24 pm Dec 04 2022
by kdxdazz
JZ05220r wrote: 06:11 pm Dec 04 2022
Tolerant to oil not gasoline, threebond 1104 and 1211 is tolerant to gasoline
Posted: 02:21 pm Dec 16 2022
by JZ05220r
kdxdazz wrote: 07:24 pm Dec 04 2022
So do you think it will be safe to use one of those on the carb holder to reeds surfaces? I was thinking i should only use it on the out side o ring that is built in to the carb holder.
Posted: 03:42 am Dec 19 2022
by kdxdazz
JZ05220r wrote: 02:21 pm Dec 16 2022
Yes, either one of those will work, 1104 fills gaps better 1211 is easier to remove, just remember to wipe everything down with thinners 10 times so it can bond
Posted: 02:58 am Dec 20 2022
by JZ05220r
kdxdazz wrote: 03:42 am Dec 19 2022
Ok having a hard time finding 1104 in the US. Not sure what a good alternative would be here. Maybe Permatex moto seal or Hondabond 4.
