2000 KDX 220 Fork Guards
Posted: 08:05 pm Oct 21 2022
by d_g_t_l
Hello!
Lurking for some time now and have resolved many issues thanks to this forum! Thank you !
I have a 2000 KDX 220 with Kayaba forks. I just recently serviced my forks and am in dire need of new fork guards/ slides.
I have looked everywhere and can't seem to find guards noted to fit or see any relative example of what will work!
Any help would be greatly appreciated :)
Re: 2000 KDX 220 Fork Guards
Posted: 11:11 pm Oct 21 2022
by JZ05220r
I’m pretty sure 04-06 rm 250 - 125 guards will work. You will need 1/4” ID 1/2” OD and 1/4” long nylon spacers for the 2 bolts on each fork leg on the front. They worked for 03 kx 250 KYB forks. Guards:
https://www.ebay.com/itm/163538755670?e ... R4y3mN7_YA
Posted: 09:14 am Oct 22 2022
by Slick_Nick
Anything can be made to work. I used to run the RM/KX style, but didn’t like the slider rings that you needed. So I had a spare set from my KX250F laying around and bolted them up without issue. Just notch the bottom if required.
Posted: 11:57 am Oct 22 2022
by JZ05220r
I never ended up using the rings for the rm fork guards
Posted: 07:24 pm Oct 22 2022
by SS109
I've run without the upper fork guard guides without issue. As long as the guard mounts up fine, you're good.
Posted: 01:28 am Oct 23 2022
If they are the stock forks, then UFO brand makes (or made, not sure if they still do) a fork and disc guard.
Posted: 12:34 am Oct 24 2022
by d_g_t_l
Thank you all I will figure it out
Posted: 02:05 pm Oct 24 2022
Posted: 01:15 pm Oct 28 2022
by d_g_t_l
Ive got Kayaba Forks, not stock - But still thanks
Posted: 07:40 pm Oct 28 2022
Would you care to guess which Japanese OEM supplier of suspension Kawasaki paid to have some forks and shocks made to their specification? :-)
Instructions on how to post a picture are in my signature. Please post a pic and we will all quit guessing as to what you have. Thanks.
Posted: 10:17 am Oct 29 2022
by Slick_Nick
d_g_t_l wrote: 08:05 pm Oct 21 2022
Stock forks were Kayaba (KYB) so that doesn't narrow it down whatsoever. What model are they off of?
Posted: 03:58 pm Feb 12 2023
by d_g_t_l
Pic here, Looks like I will try and get some KX fork guards or RM as previously mentioned.
