I'm Finally installing my Fredette Ported Cylinder and
- Molly's 70
While checking the bottom crank bearing for slop. I notice a dry, kinda sqeeking sound when the crank is turning. It's not coming from the crank seals. Maybe the water pump seal? I've never heard this from other 2 strokes I have rebuilt.
I did not notice this sound when I changed piston & rings a few years ago.
Anyone have an idea?
Bike was running perfectly before I took off the top end.
Water pump seal is original. What else could it be?
2003 KDX 220R.
2003 KDX 220R.
kdxdazz
- Country: thailand
- Been thanked: 21 times
Re: I'm Finally installing my Fredette Ported Cylinder and
As you say waterpump seal makes sense, you could take off the waterpump cover and spray some lube on it to see if it helps
- Has thanked: 13 times
My guess would be the waterpump seal as well.
- Molly's 70
Thanks, I have never heard it before.
- Molly's 70
Ok, I finally got everything buttoned up. Life
That Fredette ported cylinder made this bike what it should be. RB head. FMF with stock muffler. V Force reeds. It's quiet & runs better than it ever has.
I'm at a 38 pilot & 152 main. RB carb. I could go leaner on both, but I am staying here for now. Plug looks real good.
Thanks FRP racing.
Thanks FRP racing.
- Has thanked: 66 times
- Been thanked: 20 times
THANKS for the report!
Glad to hear it meets expectations.
- Molly's 70
I've put just over 20 miles on the new top end. Pulled the plug, looks better than I thought it would. Great color, a little dark.
I will drop 1 needle position. I'm running VP VPR w/ Amsoil 50:1.
https://vpracingfuels.com/product/vpr/?c=500
One of these days I might have to try getting my cylinder ported. I've done everything else so why not?
Man. They have jacked the prices on VP through the roof. I used to run U4.4 when racing MX. It was only $75 around 2015. $125 MSRP now, crazy.
- Tyl3r
Glad to hear you like it! I did the same cylinder and head mods and also love them. I feel like it makes the bike better everywhere with no downsides anywhere. Definitely what the bike should have been.
