220 runs better with the idle set slightly high.
JZ05220r
Post by JZ05220r »
I know it’s a kinda dumb statement but it feels so much better. Maybe because the pilot jet is set incorrectly.
Has thanked: 3 times
Been thanked: 2 times
Re: 220 runs better with the idle set slightly high.
JZ, assuming pilot jet is correctly size, then it could be:
1) Carb air screw is not correctly set (this is most desirable condition),
2) Air filter box to carb manifold leak (engine is able to suck air through leak and higher idle setting provides more fuel to balance air & fuel. But, this problem usually produces rough and ever changing engine behavior), or
3) Carb needle clip in position that is too low (like P1. P1 is bottom groove. P4 is top groove)
billie_morini wrote: 11:43 pm Jul 31 2022 3) Carb needle clip in position that is too low (like P1. P1 is bottom groove. P4 is top groove)
Just a small correction, on needles the top position is always #1 and the bottom #5.
JZ05220r
Post by JZ05220r »
billie_morini wrote: 11:43 pm Jul 31 2022 JZ, assuming pilot jet is correctly size, then it could be:
I am going to try moving the clip from the middle position to the second from top and see how that goes. Thank you
[/quote]
[/quote]
Yes, SS is correct. It's always an accident with me regarding right, left, east, west, up, down, etc. :?
billie_morini wrote: 02:17 pm Aug 27 2022 Yes, SS is correct. It's always an accident with me regarding right, left, east, west, up, down, etc. :?
It's all good my brother! I make mistakes on an hourly basis! :mrgreen:
