KIPS main exhaust shaft in wrong
Posted: 10:21 pm Jun 19 2022
Hi all-thx to this site and the cylcop. manual, just got done disassembling/cleaning/reinstalling the KIPS on our new to us 220. (Actually wasn't as hard as i thought which was nice for a change). So, quick question-when my son and i took it apart, we took special note of where the alignment dot was at on the shaft lever in relation to the main shaft gear as i didn't see any white paint on the end of the spline. Even took pics of it on my phone to make sure. Once out, i ended up painting it white for future reference. Then, once i put it all back together, i noticed that my mark was 180 degrees off and that there actually was a small white dot on the END of the spline that i could line up with the dot on shaft lever (hope all that makes sense). So, somewhere along the line, a PO messed up and didn't follow all the alignment marks to get things right. Question is, how would that make the bike run with the main shaft off 180 degrees as opposed to having it in the correct position now (assuming the PO had the sub valves & shafts lined up correctly-i didn't check that when i removed them). Thanks tons guys
