Top end swap?!
Ecarta
Top end swap?!
Post by Ecarta »
Hello fellow KDXers:
Question: Is it OK to swap my KDX top ends? Both are 2004.
On KDX #1, I did a complete engine rebuild. But its proving to still have have bottom end problems but the top end is fresh. (Newly replated cylinder, new piston and rings.)
KDX #2 has a tight bottom end, but top end is average at best (rings are shot, cylinder could use a replate, no scoring but some blotchy patches on cylinder wall.
Can't afford to replate KDX #2's cylinder right now, but could do new piston and rings. But seems to run fine just not as zippy as it could be.
Just doing a top end swap would match up the best bottom end with best top end. And would be the cheapest option for now. I can always rebuild bad kdx top end later on.
Thoughts? Suggestions?
Re: Top end swap?!
Post by John_S »
I would think you'd be good to go with a gasket kit and some coolant. There isn't anything special that was done to mate each cylinder with its original case halves.
Re: Top end swap?!
No problem swapping them. Go for it!
Ecarta
Re: Top end swap?!
Post by Ecarta »
John_S wrote: 02:49 pm May 17 2022 I would think you'd be good to go with a gasket kit and some coolant. There isn't anything special that was done to mate each cylinder with its original case halves.
Ok great thanks for feedback!
Ecarta
Re: Top end swap?!
Post by Ecarta »
SS109 wrote: 06:11 pm May 17 2022 No problem swapping them. Go for it!
Ok ss109 will do! Thanks for feedback!
Re: Top end swap?!
yep, gasket kit and coolant
