Starting Issue
Dekon
Starting Issue
Post by Dekon »
Hello all,
I seem to have a very strange starting issue. When the bike is cold started it will run for 2 to 3 seconds and die. It will do this 15 to 20 times then it will run fine. If I even look at the throttle, the bike will stall. I've cleaned the carb so many times I can do it with my eyes closed. I know you can not dip the carb because it will ruin the gasket in the carb. So I never dipped it. This has been happening since I totally rebuilt the bike. It is so annoying. Any suggestions on what to try?
Re: Starting Issue
Find a friend with a nice running KDX and switch carbs. If it improves things, call Ron Black.
Re: Starting Issue
Replace the jet block gasket anyway.
Re: Starting Issue
Sounds lean or possibly you have the idle set too low. With a fresh top end the engine is pumping more air which could cause it to be slightly leaner than before. More compression could also lower idle speed so therefore require a higher idle setting.
Dekon
Re: Starting Issue
Post by Dekon »
Thanks guys, I am going yo replace the jet block gasket and then check the jetting.
Re: Starting Issue
also check your fuel delivery.
