Exhaust Gasket
Laurenz_KDX200
Country: Germany
Exhaust Gasket
Post by Laurenz_KDX200 »
Hi :)
What kind of exhaust gasket is used between cilynder and exhaust? Mine is missing…
Greetz
Has thanked: 13 times
Been thanked: 21 times
Re: Exhaust Gasket
Are looking for the o-rings that seal the pipe or the "gasket" that sits between the opening of the cylinder's exhaust port and exhaust pipe opening? The o-rings, which are rubber, are part# 670E3039. If you're looking for the other, part# 11009-1995 is what you need. It's just a fancy copper ring. It's mainly there, IMO, just to protect the aluminum cylinder from getting worn from the steel exhaust pipe vibrating against it. The rubber o-rings on the pipe do the actual sealing of the exhaust.
Laurenz_KDX200
Country: Germany
Re: Exhaust Gasket
Thanks for your reply :) ok i will look for the parts in ebay, herr in Germany its probably more difficult to get the parts ☝🏼
Laurenz_KDX200
Country: Germany
Re: Exhaust Gasket
Isnt there a special tape or trick how i can raplace it wirh home remadies?
Been thanked: 2 times
Re: Exhaust Gasket
O rings are pretty universal. Any hardware store should carry an assortment for you.
Laurenz_KDX200
Country: Germany
Re: Exhaust Gasket
Ah nice, thanks for the hint!!!
Re: Exhaust Gasket
I've used high temp sealant RTV in a pinch when reusing old o-rings or no or-rings at all.
Has thanked: 66 times
Been thanked: 20 times
Re: Exhaust Gasket
"670E3039" means 3.0 x 39
A cheap one won't last as long as the proper one. Look up various o-ring specifications, such as Buna-N (cheap), Viton (better) and others.
JimmyB
Been thanked: 3 times
Re: Exhaust Gasket
Post by JimmyB »
Look for a local business in Germany that deals with bearing and seals,they usually will carry o-rings also,As KDXGarage mentioned Viton is better,I usually get them in a 10 pack as they are very cheap..
Or you can go this route,I have used it many times for repair work out in the field on machinery, works great..
02 KDX220
Laurenz_KDX200
Country: Germany
Re: Exhaust Gasket
I will ask a local dealer, thanks for your support :)
