Head lamp replacement
Posted: 07:45 am Mar 12 2022
by targetman
It's time for me to replace the headlamp. OEM?
Re: Head lamp replacement
Posted: 12:29 pm Mar 12 2022
by SS109
If you don't use your headlight, and only have a stock lighting coil, then I would go OEM or something similar. If you actually do use it and have a higher output coil there are a lot of great options out there. It just depends on the lighting you need/want.
Posted: 12:46 pm Mar 12 2022
by targetman
Bikes for sale so OEM it is. Thanks.
Posted: 05:44 pm Mar 12 2022
by SS109
In that case, a Polisport MMX might be a cheaper option but you have to mod the wiring a bit.
