Head lamp replacement
Re: Head lamp replacement
If you don't use your headlight, and only have a stock lighting coil, then I would go OEM or something similar. If you actually do use it and have a higher output coil there are a lot of great options out there. It just depends on the lighting you need/want.
In that case, a Polisport MMX might be a cheaper option but you have to mod the wiring a bit.
