Front Brake Caliper/Axel Compatibility
gumbo583
Post by gumbo583 »
I just did a stem swap, I put the stem into 2004 kx125 clamps. I’m wondering if I can use my stock caliper, and I am also wondering what years of KX axels can I use that would fit the 2004 clamps.
Has thanked: 13 times
Been thanked: 21 times
Re: Front Brake Caliper/Axel Compatibility
Not sure on the axle but I know the caliper should bolt on. I'm using my stock '98 caliper on my my '06 KX250F Showa forks.
Has thanked: 66 times
Been thanked: 20 times
Axle:
This Kawasaki 41068-0004 AXLE fits the following models and components:
Kawasaki Motorcycle 2014 KX250F - KX250ZEF Front Hub
Kawasaki Motorcycle 2006 KX450F - KX450D6F Front Hub
Kawasaki Motorcycle 2005 KX250 - KX250-R1 Front Hub
Kawasaki Motorcycle 2009 KX250F - KX250W9F Front Hub
Kawasaki Motorcycle 2009 KX450F - KX450E9F Front Hub
Kawasaki Motorcycle 2004 KX250 - KX250-M2 Front Hub
Kawasaki Motorcycle 2018 KLX450R (Australian) - KLX450AJF Front Hub
Kawasaki Motorcycle 2007 KX250F - KX250T7F Front Hub
Kawasaki Motorcycle 2006 KX250F - KX250T6F Front Hub
Kawasaki Motorcycle 2019 KLX450R (Australian) - KLX450AKF Front Hub
Kawasaki Motorcycle 2010 KX250F - KX250XAFB Front Hub
Kawasaki Motorcycle 2013 KLX450R (Australian) - KLX450ADF Front Hub
Kawasaki Motorcycle 2006 KX450F (European) - KX450D6F Front Hub
Kawasaki Motorcycle 2005 KX250F - KX250-N2 Front Hub
Kawasaki Motorcycle 2009 KX250F Monster Energy - KX250W9FA Front Hub
Kawasaki Motorcycle 2014 KX450F - KX450FEF Front Hub
Kawasaki Motorcycle 2011 KX450F- KX450EBF Front Hub
Kawasaki Motorcycle 2007 KX450F - KX450D7F Front Hub
Kawasaki Motorcycle 2012 KLX450R (Australian) - KLX450ACF Front Hub
Kawasaki Motorcycle 2015 KLX450R (Australian) - KLX450AFF Front Hub
Kawasaki Motorcycle 2010 KX450F - KX450EAF Front Hub
Kawasaki Motorcycle 2012 KX450F - KX450FCF Front Hub
Kawasaki Motorcycle 2009 KLX450R - KLX450A9F Front Hub
Kawasaki Motorcycle 2009 KX450F Monster Energy - KX450E9FA Front Hub
Kawasaki Motorcycle 2008 KX250F - KX250T8F Front Hub
Kawasaki Motorcycle 2008 KLX450R - KLX450A8F Front Hub
Kawasaki Motorcycle 2007 KX250 - KX250R7F Front Hub
Kawasaki Motorcycle 2006 KX250 - KX250R6F Front Hub
Kawasaki Motorcycle 2013 KX450F - KX450FDF Front Hub
Kawasaki Motorcycle 2011 KX250F - KX250YBF Front Hub
Kawasaki Motorcycle 2012 KX250F - KX250YCF Front Hub
Kawasaki Motorcycle 2005 KX125 - KX125-M3 Front Hub
Kawasaki Motorcycle 2004 KX250F - KX250-N1 Front Hub
Kawasaki Motorcycle 2004 KX125 - KX125-M2 Front Hub
Kawasaki Motorcycle 2008 KX450F - KX450D8F Front Hub
Kawasaki Motorcycle 2014 KLX450R (Australian) - KLX450AEF Front Hub
Kawasaki Motorcycle 2013 KX250F - KX250ZDF Front Hub
