The first start was uneventful. Bike ran like a top, although super rich from what I could tell going up and down the street. Ended up 3 steps leaner than stock on the pilot, 2 steps leaner than stock on the main. Ran amazing after that. Loaded 'er up and took it to the track for a proper break in.
Unfortunately, after beating the piss out of it for a good 20 minute moto, it seized on me in the air. I pulled the clutch in just in time and was able to keep from crashing, despite the nosedive. I looked down, and my left boot was covered in coolant. The radiators were ice cold. Upon closer inspection, one of the head studs was missing. Good thing I had another bike that day! Got it home, cleaned it up, and went to diagnose the issue.
I got lucky. Once I had the bike clean, I tried kicking it over, and it actually fired up on the first kick. I immediately shut it off, and decided to do a top end anyways. The piston was toast, the cylinder was in great shape. I deglazed it, ordered a new piston and gasket set. Remember before, when I said "don't trust other people's work?" Yeah, well I had assumed that the head studs were installed properly. I never checked them. In this engine, the studs go down into the water jacket, so when the one stripped out, it let all the coolant spray out, allowing the bike to overheat. I was in the middle of a good moto, so I never thought to look down, I had already done a few shakedown motos, with no issue.
At this point, I removed all the studs, repaired the stripped hole, checked the rest, and installed new studs where reuired, using a thread sealing compound. Installed a new top end a week later, and she was back in business.
