Rear tire size suggestions
Posted: 10:33 am Sep 03 2021
by Kilzer23
I haven’t had any luck locating an 18X2.15 kdx wheel so I’m opting out for an 04 KX 250 wheel for my H series kdx (19X1.85) I was wondering what tire size I should go with/what would work? I plan on most woods riding with the ability of taking the bike on a short trip into town. Any and all suggestions are greatly appreciated!
Re: Rear tire size suggestions
Posted: 10:56 am Sep 03 2021
by Slick_Nick
Why not just get an 18" TUSK wheel from rocky mountain? They work awesome. 19" sucks for off road.
But if you insist, run whatever tire size you want. 110/90/19 might work? You could end up having to go to a thinner tire to get that 19" rim to clear the swingarm pocket where the mud flap sits.
Posted: 11:28 am Sep 03 2021
by Kilzer23
Slick_Nick wrote: 10:56 am Sep 03 2021 Why not just get an 18" TUSK wheel from rocky mountain? They work awesome. 19" sucks for off road.
I would get an 18 in tusk, but the problem isn’t my back wheel itself, it’s the hub. It won’t hold bearings and it has been JB welded over a crack I’m assuming. I’m only going with the kx wheel because it’s the only hub I can find that won’t cost me $250+
Posted: 03:37 pm Sep 03 2021
by bufftester
Same rear hub is on the 2006-2007 KLX250S, 94-96 KLX250R, 97-2007 KLX300r, 93-96 KLX650R. Saw a couple on Ebay for under 150$. Could lace it to your existing rim, way better than going to a 19" tire IMO
Posted: 06:41 pm Sep 03 2021
by SS109
Let me dig through my spare parts as I might still have a KDX rear wheel assembly.
Posted: 12:27 pm Sep 05 2021
by pumpguy
Keep in mind that the E series rear wheel can also be used on your H series. Might have to mess with spacers, IDRRN. I have one of each with different tires that I can swap for my H series.
Posted: 04:23 pm Sep 05 2021
2003 and newer KX125 / KX250 rear wheels are 25 mm bearings.
Save up and buy the correct hub / wheel.
Posted: 07:32 am Sep 08 2021
by MoonStomper
Good stuff here! I want a spare for my H that I can keep a soft terrain tire on.
Posted: 05:53 pm Sep 08 2021
by Greenbandit200
Goint to a 19 will change your gearing a bit too. I'm not sure how much but probably a noticeable amount. You might have to change sprocket and chain length to compensate? I would lace a new hub to your stock rim if possible.
Posted: 01:11 pm Sep 14 2021
by Kilzer23
SS109 wrote: 06:41 pm Sep 03 2021 Let me dig through my spare parts as I might still have a KDX rear wheel assembly.
Thank you! I would greatly appreciate that!!!
Posted: 01:13 pm Sep 14 2021
by Kilzer23
Thank you everyone! There is some really good stuff on here! I am going to continue to dig around the internet and see what I can find! In the meantime I appreciate every single one of you on this website you all have been very helpful!
Posted: 03:22 pm Sep 14 2021
Thanks! Keep at it.
Posted: 04:49 pm Sep 14 2021
by Molly's 70
Keep your eye on Ebay. I found mine there.
