Water coming out of head bolt
Posted: 11:25 am Jul 05 2021
by Jack Johnson
Back together after complete rebuild, I have antifreeze leaking from one of the head bolts. I'm guessing the new head gasket was bad somehow. Anybody else have this problem?
Re: Water coming out of head bolt
Posted: 03:07 pm Jul 05 2021
by Molly's 70
Never had the problem. Which bolt is it leaking out of?
Posted: 09:19 pm Jul 05 2021
by Jack Johnson
Left side right behind the water hose. You can see the water seep out of the threads.
Posted: 09:35 pm Jul 05 2021
Was the rebuild after normal wear or after a meltdown?
Did you remove the studs?
Posted: 06:31 am Jul 06 2021
by Jack Johnson
Meltdown I suppose, the bike needed a complete rebuild.
I did remove the studs.
Posted: 12:24 pm Jul 06 2021
by TwistedRoot
Could it be that your cylinder head is slightly warped?
Posted: 01:21 pm Jul 06 2021
by Molly's 70
Put your head on a piece of glass & check for flatness with a .002 feeler gauge.
Posted: 08:08 am Jul 07 2021
by Jack Johnson
That is on the agenda for today.
Posted: 09:47 am Jul 15 2021
by Jack Johnson
Checked head with feeler gauge, doesn't seem warped. Used some 220 grit sandpaper on some glass just to be sure.
