Overly rich jetting
Isgc
Overly rich jetting
Post by Isgc »
Lately I have been trying to get my 93 jetted correctly but it runs quite rich no matter what changes I make. I have tried the stock jetting to no avail. I have also dropped the pilot to a 42 with still nothing. Tried different main jets too. No matter when jets I put in this thing, it still runs rich and smokes like crazy. Float height is set properly, and I do not burn trans oil. Engine is solid. Is it possible that my problem could be a worn out jet block gasket? I read somewhere else that a worn jet block gasket can cause a rich condition. Any help is appreciated. Thanks guys
Re: Overly rich jetting
I would replace the jet block gasket.
Has thanked: 66 times
Been thanked: 20 times
Did you soak the carb to clean it? If so, there's your answer.
Isgc
Post by Isgc »
KDXGarage wrote: 05:37 pm Jun 24 2021 Did you soak the carb to clean it? If so, there's your answer.
The block gasket would indeed cause my problem then?
Has thanked: 13 times
Been thanked: 21 times
Isgc wrote: 06:04 pm Jun 24 2021
Yes, jet block gasket will cause this problem. Also, what did you set your float height at, factory 16mm? If so, change it to 18mm as that can also contribute to a rich running condition.
There are much many threads on here and elsewhere with old, worn out jet block gaskets or "carb dip" damage.
