KDX 220 Supermoto Rotor
Actionjackson915
Hey! Does anybody know where to get a 320mm or so front rotor and caliper relocation bracket for the stock hub and forks? Or should I suck it up and go with KX stuff. Also what is different between the rotors? Thanks!
Re: KDX 220 Supermoto Rotor
If you decide to go the KX route, the 92-02 KX125/250 front rotors are the same as the 97-07 KLX300, but you would also need a KX front hub as the hole size is different IIRC. The KDX uses an 8-15 bolt on the disc and the KX uses a 6x14.5
Galfer makes a KX oversize rotor and bracket
