clutch wear on kdx220r
Posted: 07:29 am Mar 29 2021
**not the important part ** Hello this is my first post after finally getting to rebuild and ride a kdx220 that my dad bought years ago that had a water pump failure, and was commonly run on both salt flats and beach front. As you might imagine this left the bike very rusty, i had to replace every bushing and bearing both inside and outside the engine and clean and "de-rust" the original parts like the gears. after putting it all together I have a super tight gear box (always want to hit neutral) and a list of complaints and loves about my fresh baby.
**important part**
this leads me to my recent dilemma. after about 150km of forest riding I noticed that the clutch pull wasn't fully designating the clutch, after testing the cable, and using a shifting spanner to fully swing the lever arm I noticed that it was a problem inside.
after removing the cover it became obvious that the as kdx parts house puts it "LEVER-COMP,CLUTCH REL" had rolled its edge. to fix this i replaced the washer behind the pusher pin thing to a slightly thicker one (0.3mm thicker).
I was wondering has anyone had this issue before and if so is this the right way to fix it?
now when the clutch is in if the rear wheel is in the air it does start to spin the tire. but full clutch out there is very slight play in the engine case lever. is this normal/ ok if not any suggestions? I do plan on shortening the clutch lever to get a bit more pull.
**important part**
