Greasing the KIPS
Posted: 10:08 am Apr 29 2006
by k.d.x.
I tore apart the top end on my 91 and saw that I needed to replace the valves. So I ordered both of them and replaced them. As I took everything apart I cleaned each piece painstakingly well and dry fit it all back together before I did it for real. When I dry fit it, I could move the entire system by using the main rod, the main valve and it was easy to move. So now I put the grease like is instructs me to to do but when I put it all back together there is obvious resistance. Not metal to metal but just from the grease.. Is that right?
THanks
Posted: 10:25 am Apr 29 2006
by KDXer
I used two stroke oil, not grease.
Posted: 10:30 am Apr 29 2006
by Indawoods
Valves?
Posted: 08:10 pm Apr 29 2006
by k.d.x.
Indawoods wrote:Valves?
Did I miss something?
Posted: 08:24 pm Apr 29 2006
by Indawoods
What valves are you talking about? Do you have a part number?
Posted: 08:36 pm Apr 29 2006
by k.d.x.
Indawoods wrote:What valves are you talking about? Do you have a part number?
12005-1121
It's the exhaust valves
Posted: 09:04 pm Apr 29 2006
by Indawoods
The sub port valves I imagine... buykawasaki.com is down right now.
What was wrong with them? Gears fried or burn up?
Posted: 11:25 pm Apr 30 2006
by 89kdx200rdr
use two stroke oil on them the same oil you put in your gas not grease
Posted: 09:19 am May 01 2006
by m0rie
If its a 91 they were most likely stripped Inda.
Posted: 02:07 pm May 01 2006
by canyncarvr
Don't use grease unless specifically instructed to do so in the manual. As stated, I recall the manual calling for oil more often than grease.
That said, grease certainly increases resistance. Take a wheel bearing as an example. MUCH easier to move one with no grease. That sure doesn't make it better.
re: Did I miss something?
Just a bit of a gibe is all.
If there's a 'both' of 'em...it's the subport drums he's referring to.
...you knew that....
Posted: 10:53 am May 02 2006
by k.d.x.
My goodness.... so much hoopla over using the term "valves"!!!
Below is an exerpt from the service manual. This is why I used the word valve, and this is why I questioned about the grease. If so many people are just using 2-stroke oil to lube the kips, can this be why there are so many issues with the KIPS valves needing to be replaced so often? Just a thought.... but WTF do I know?
Oh.... yes, the teeth were grinded down on the gears on one side but I figured what the hell, I might as well replace both since I'm in there.
“-Apply a Molybdenum disulfide grease to the following:
Exhaust valve upper and lower journals
Exhaust valve pinions
Valve guides(inside)
Valve operating journals
Valve operating valve jack
-Adjust the exhause valve position in accordance with the following procedure:
After installing the rod retaining screw in the cylinder with the valve operating rod, pull the rod to the right side as far as it will go.......”
Posted: 11:50 am May 02 2006
by canyncarvr
No hoopla.
I was simply defending your (correct) use of the word.
I won't do it again! I
promise!
Doan want no hoopla goin' on!
