Engine Knocking Upon Hard Deceleration
Dutch-MI
Well I took out the '88 KDX for the first time after break in of the new top end.
Everything ran great with the exception that when I would decelerate hard, I got a knocking / rapping noise from the engine. This wouldn't happen every time - mostly when I was in 4th or 5th at high speed and then decelerating or coming down a hill and downshifting.
I checked the rod for any up and down play when I had the head off and there didn't seem to be any.
Has anyone experience this before? If so, what did you find out was the reason?
Really appreciate any input.
- Has thanked: 67 times
- Been thanked: 20 times
Re: Engine Knocking Upon Hard Deceleration
Did you have the clutch pulled in?
Which octane of gasoline do you run?
Dutch-MI
Only pulled the clutch in to shift gears but cant remember if i did that every time.
Used rec gas with 40:1 amsoil interceptor
rec gas??
targetman
What is the octane??
Dutch-MI
- ericr
Could it be chain slap? Check the tension and condition of the sliders.
That's not a lot of octane. Make sure it is not detonation.
Dutch-MI
Not chain slap.
Sounds like detonation. Any way i can determine if it is?
If 90 octane isn't enough, what else can i get?
Do you not have higher octane in your area? Can you go to a marine gas station? I hear you all have a lake or two in Michigan. :-) A buddy here in AL (member here, treelimb) gets 93 octane non-ethanol at a marina.
Dutch-MI
Dutch-MI
Well I mixed 50% 90 octane rec gas and 50% 110 octane race gas to get 100 octane. I only get slight knocking for about the first minute of gentling riding it around after it's warmed up. No knocking on hard deceleration anymore however my last ride was on a slow single track and not a big open loop like before.
