1987 KDX200 flywheel won’t come off
Apk_kdx
Post by Apk_kdx »
I just bought an 87 kdx200 and realized that my stators could be busted but I can’t remove them or anything since my flywheel won’t come off. Any suggestions on how to do it?
Has thanked: 66 times
Been thanked: 20 times
Re: 1987 KDX200 flywheel won’t come off
Welcome to kdxrider.net.
Get a steering wheel puller, some washers and a couple of long 6 mm bolts. Grease the end of the bolt in the crankshaft. Even better is to replace the stock bolt with one from a hardware store (metric socket head) and let the puller shaft turn on that instead of the stock bolt.
Apk_kdx
Post by Apk_kdx »
Thank you. I’ll try that and if this isn’t surface rust I think I’ll get a new one
