Hey fellas,
I was wondering after such an install is there a "break-in" phase that is required for a new Piston? Thanks much!
Installed New Piston and Top end
- G22inSC
Re: Installed New Piston and Top end
That's a hotly debated question just like what oil to run or what ratio mix. There are posted break-in procedures yet there are also other's that live by just riding it like you stole it. My opinion, follow a break-in but that's just me.
'10 Honda Recon (wife's)
'08 Kaw KX65 (Sold)
'07 KTM 50SX Sr. (Sold)
'09 Yam PW50 (retired)
'97 Kaw KX250 (Sold)
Gallery
2005 KDX200 Bike Profile
'08 Kaw KX65 (Sold)
Gallery
Check this out, straight from Wiseco. Interesting that at no point do they recommend letting it sit there and idle. I like this method, its right in between long drawn out idle sessions and riding it like you stole it.
http://blog.wiseco.com/proper-engine-br ... -a-rebuild
- Country: New Zealand
A new piston and rings you really just need to make sure you warm it up slowly, head out and ride for a few minutes. dont go WOT straight away, but just ride. Then come back and check for any leaks. If you do that 2-3 times the rings should seat fine.
anything mechanical thats new and wearing in you want it to be able to take its time - so avoid revving hard when cold or WOT too early, but equally dont overload the engine by lugging/idling it for long periods of time (idling will create excess heat) - the piston rings will take longer to seat and you're better to wear them in at similar RPM's to usual operation.
I replaced my top end last spring along a with fresh replate. It was warmed up and ridding as usual as break in. 5 tankfulls later all's well.
- Country: Usa
Getting on it too early can sieze the piston. I did this with a yz125 after letting it idle a while The scuff was minor, but it was enough to verify that better to take it easy. Now I had warmed up many a bike with a 15 minute idle only then a 15 minute ride no more than half throttle many times. I changed to the recomendation of the person that bores my bikes. Start it for 1 minute 5-6 times letting it cool to room temp in between, a fan speeds it up. Then ride an hour taking it easy and making sure the bike is not lean. Then work your way up checking the jetting for about another hour.
Another thing I have always done that is debated, I warm the bike up until the pipe is hot to the touch before I ride it to ensure I have no abrupt thermal transient. But many just kick and go with no problems. I prefer to error to caution.
