steering stem bearing replacement questions
Posted: 10:29 pm Jun 21 2020
I'm working on replacing the steering stem bearings on my '01 KDX200.
I have two questions that I wonder if you guys can help me with:
1. The service manual says that if either of the bearing needs replacing to replace both bearings and races. On mine, the race on the
lower bearing was scored a bit, so I've gotten the lower bearing replaced and have installed a new race. But, the top bearing
still looks to be in good shape along with the race. I'm planning to leave the top one as is, but I'm wondering why the manual calls
for both bearings to be replaced?
2. I'm trying to adjust the steering and tightened up the stem adjustment nut to 43 inch lbs, but it seemed tight to me. So, I backed
it out until I could feels a wiggle in the steering. I then tightened it up until the wiggle went away. I then tightened up top triple clamp bolt to
33 ft lbs. But, now I'm second guessing myself and wonder if I should tightened the stem adjustment nut a little more. Do you guys know if
there's any harm in having it a little loose, or is it better to error on the side of little tight?
