KDX 125 exhaust
- Country: Greece
KDX 125 exhaust
Hello guys, Im looking to change pipes on my 125 anyone has some reccomentations.I cant find anywhere aftermarket exhausts for my 125
- Country: Japanese version
Re: KDX 125 exhaust
Kx 125 ? And adapt exhaust port to take o ring fitting instead of flange? My kdx 250 original exhaust was a flange fitting... I used 12mm thick aluminium plate . Cut to the shape of the original flange. Cut hole for fmf exhaust. Remove the two studs and use Allen key bolts to bolt aluminium flange on.. recess Allen key bolt so flush with flange... also need to make tabs on aluminium plate for exhaust springs..... also compare kdx and kx 125 shape to make sure they are the same.... kdx 250 and kx 250 are identical apart from the exhaust port end... Japanese version sr... I am sure us kdx is different again
Re: KDX 125 exhaust
https://www.ebay.com/itm/KAWASAKI-KDX12 ... 0332984173
https://www.domaracing.fr/shop/gb/echap ... 92-04.html
https://www.deppipes.com/product-listin ... encer/file
https://www.mandp.co.uk/products/kdx125 ... ipe-523986
DEP, HGS, Doma
I have NO EXPERIENCE with either of those. I am suggesting that you research them.
DEP, HGS, Doma
