Leaking carburetor boot/holder
Posted: 09:57 am May 03 2020
Hi all,
Have a KDX that I have rebuilt slowly and had issues with. After doing topend and revamping bike it had issues starting and was chasing a few things. Replaced the coil and that got spark back but couldn't get it to fire until spraying some "Start ya Bastard" starting fluid. It got it going but won't use it again.
Explored the possibility of a leak and found the ''packing'' seal on the right KIPS shaft was leaking. Went back in and replaced that which sealed up the top end and then did the leak down test again which showed that it was holding pressure in a leak down test. Unfortunately while I was in there I noticed the bore looked a bit rough and seemed to have a small crack and got that welded and a new coating to bring it back to new.
So have just put it all back together and did another leak down test to see how it is and now there is a leak from the carburettor holder. New gasket was installed against the engine intake then reed block and then carb holder. Pressure leaks straight away on the left upper side through one of the release areas built into the carb holder. (Circled on the photo). It wasn't doing that before when i checked it prior to this replating and reassembly. Nothing has changed.
I believe when i first pulled it down there was some kind of silicon sealant in there and the previous owner was trying to jet the bike to get it to run right. Certainly if this is the issue I'll be happy as that is probably why the thing wasn't starting the way it should. Everything else being new (Lectron carb, gaskets, good new piston, rings and reeds and clean air filter, new spark plug and fuel).
After finding the leak from between the reed block and the carb holder on upper left side I reassembled and made sure all bolts were tight. Still leaking. The white insert in the reed block that channels the air seems a bit loose but it looks like that is how it should be. The raised circular seal that sits against that on the carb holder feels good but the rectangular one doesn't seem particularly high compared to the flat carb holder surrounding that. All surfaces have been cleaned.
Is the whole area supposed to be black rubberised but the bronze area shows where that has been worn away? The fact that it leaks from the small lower release channel indicates that it is leaking from both the circular seal and the rectangular one. Do i just replace 160651298 Carb Holder (not cheap) or does perhaps the fact that the white internal built of the reed block also need replacing (which only can be done by replacing the valve assembly reed - 120211067)?
Seems a bit drastic. The weird thing was that there didn't seem to be a leak there before. Although that would explain the hard to start issue. Making a gasket would lift the circular seal even further away from the white part of the valve assembly reed and create messy air intake. Silicon sealant? Seems like it would also be a problem.
Has anyone else had this or have any suggestions? The air pours out in a loud hiss so it is not small.
