Top in rebuild, gasket thickness?
arkdxrider
Post by arkdxrider »
I see on some other bikes there is a piston height measured within the cylinder and the use of different gaskets of different thicknesses to have the compression right....
I'm guessing these old KDX's aren't that far up on the cutting edge and there is no real reason to measure when just replacing with the wiseco piston and stock gasket?
Re: Top in rebuild, gasket thickness?
Nah, you will be OK.
