Shifting through gears test problem
2005 KDX 220. After building the bottom end and putting cases back together, I was trying to go through the shift pattern but could only go like 2 shifts before it would not keep shifting. Is this normal or do I have a problem? Thanks for your time.
Re: Shifting through gears test problem
Are you wiggling the front sprocket back and forth?
Yup. You gotta rotate the sprocket for the trans to continue shifting.
Thanks...that seemed to work. Thanks so much for the help. The shop manual only tells you so much.
Awesome!
