First Time Plug Chop
Posted: 01:46 am Feb 20 2020
by Goat
Can I tell anything from this exercise, given the mistakes I made?
Picked too short of road so only got thru 4th.
Did not get it shut down as fast as I think I was suppose to when i pulled the clutch in.
It is harder to find a deserted 1/4 mile strip than I expected.
Re: First Time Plug Chop
Posted: 03:21 am Feb 20 2020
This was a new plug?
Posted: 06:39 am Feb 20 2020
by kdxsully
Looks lean.
Posted: 12:06 pm Feb 20 2020
by Goat
Yes. This was new plug.
I am thinking it really doesn’t tell me what I need to know. Or I could make false judgement.
The bike does not “seem” lean by the seat of pants + based on the fair bit of smoke & spooge it produces.
I think I should probably find a better road and try again.
Posted: 12:17 pm Feb 20 2020
by kdxsully
Could be a bad crank seal too I think. Try again
Posted: 12:55 pm Feb 20 2020
The band needs to be down toward the bottom.
I think the wide portion is the "did not get it shut down soon enough" portion.
viewtopic.php?t=12283
Posted: 02:13 pm Feb 20 2020
by Goat
Thanks gents! I’ll try/try again.
Posted: 02:17 pm Feb 20 2020
and this is a KDX50, correct? KDX80?? :-)
Posted: 01:14 am Feb 21 2020
by Goat
Hah! I do need one of those, though. My 50 is a mini trail and it just collects dust since the KLX140 came home.
Posted: 10:26 am Feb 22 2020
by John_S
You don’t need a longer road. I’ve done this multiple times and it works great.
Fully warmed up engine
New plug 1st through 4th wide open pull in the clutch but don’t kill the engine. Turn around and do 1st through 4th again this time pulling in the clutch and killing the engine. That few seconds of idling while turning around is not going to ruin your reading. You could even do 3 or 4 1st through 4th runs. Only doing wide open and clutch in idling to turn around. Main thing is no half throttle or compression braking. Cut the plug like you did and you’ll have a good main jet color band showing what you need to do next with jetting. Wet cardboard color 2mm band down low on the plug would be perfect.
Posted: 10:49 am Feb 22 2020
by John_S
Check out this thread. These were some plug chops I did. Never got into 5th or 6h gear. It was 2 different engines but shows the different looks of the plug with 3 different main jet sizes.
viewtopic.php?f=86&t=23507
Posted: 09:50 pm Feb 22 2020
by kdxsully
John_S wrote: 10:49 am Feb 22 2020
Excellent post.
Posted: 02:59 am Feb 23 2020
by SS109
I didn't say it before but I will now. That is one of the most informative threads I've ever read on a forum. Kudos!
Posted: 12:45 pm Feb 23 2020
by Goat
That is the post that got me itching to do some chopping. It sis a great one.
I really appreciate the info and possibility to run just to 4th gear.
I still have to find new road, since I met the neighbors there on my first try. And they asked if I could find a different route. Thanks very much.
Posted: 07:18 am Feb 25 2020
by John_S
Thank you guys!
