				TT question
				Posted: 05:33 am Apr 10 2006
				by Ryan
				I am putting on my triple tree right now. I dont know the order though that the washers and other spacers go in. Could someone help me a bit. I also have the spacer thingy from phil so please take that into account. Thanks
				Posted: 09:22 am Apr 10 2006
				by m0rie
				Ryan - Look at the diagram on the buykawasaki site.  It should show the correct order.
				Posted: 11:30 am Apr 10 2006
				by Ryan
				it does show it, i loooked in the manual but does the order change because of extra spacer. Also how do the forks mount on the tt if they are spread farther apart because of the spacer.
				Posted: 01:26 pm Apr 10 2006
				by canyncarvr
				re: far apat
It don't matter.  However far apart they are, the forks will generally be at least level to the top clamp.
With the KX setup, though...you will probably have to raise the forks a good bit in the clamps to get the bike back to 'level'...or to the same attitude it was with the OEM forks.
Well...considering the bike is setup with the OEM pull rods, running an 18" rear/21"front wheels with 'standard' sized tires etc. etc.
Is there a particular item you have a question about otherwise?  There isn't a whole lot of choice in how things go back on.
				Posted: 04:26 pm Apr 10 2006
				by Ryan
				nope, i figured it out real nice.
